metoooo Samba Member
Posted: Mon May 25, 2015 7:22 am Post subject: 83mm kit wont fit |
Hi,
I have a 1200cc D code engine case that I've bought a set of AA 83mm over size kit to install in.
The problem is that the case cylinders opennings are 90mm and the AA cylinders are 87 at base.
Someone here face this issue?
Any idea how to solve this? |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Mon May 25, 2015 4:07 pm Post subject: |
sounds like some body cut it [case] to fit 85.5mm [1600] cylinders, they are 90mm on the case openings stock.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
spencerfvee Samba Member
Posted: Mon May 25, 2015 6:18 pm Post subject: Re: 83mm kit wont fit |
you might have a bus case .they were 1500cc they had a 69mm crank and 83mm clys spencerfvee
metoooo wrote: |
Hi,
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Mon May 25, 2015 9:55 pm Post subject: 83mm kit wont fit |
D cases have the same size openings as a 1600, they had supper thick cylinders. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Tue May 26, 2015 4:06 am Post subject: |
I've just found out that this is a later universal case, there are a sets of 77mm p&c kits with 90mm on buttom but it's very hard to find those.
Is there a way to make the order (87mm) type fit the new case ? (shims, spacers, rings...) |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Tue May 26, 2015 11:47 am Post subject: |
Some formula vee guy said they used Viton o-rings to fill the gap.
But I cant guarantee the longlivety of that. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Wed May 27, 2015 4:50 pm Post subject: |
It's not a universal case. It's that VW changed the D series 1200 block to have the same 90mm openings in August 1969 as their other engines, along with 1200 cylinder/jugs sized to match... and all German 1200 D-blocks up to the end of production in early 1978 were made that way. D blocks made for model years 1966-69, same as the 61-65, had the smaller opening and that's what the big bore kit is for. As far as I know, there are no big-bore kits, only standard 77mm kits are available for those late 1200 German cases.
I've always been a bit skeptical about the whole Viton ring as a spacer thing. For a Vee where the engine runs only a few races before it gets torn down again, that's one thing, there's only a few heating/cooling cycles. But in a driven car that will see years of use under all kinds of conditions? I think I'd rather have something more than a synthetic rubber ring there. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Sun May 31, 2015 1:46 pm Post subject: |
metooo, do you have any other engine parts for that case? Such as crankshaft, connecting rods, cylinder heads, flywheel? If not, you could use that case to build a 1679cc engine that does not require any case machining.
-Crankshaft: A 1200cc 40hp (34hp European) or later.
-Connecting rods: 1600cc stock type
-Camshaft: stock or slightly enhanced
-Cylinder heads- If your case is a single-oil pressure relief, then it'd be best to stay with single-port heads with the 35mm intake valve size and 32mm exhaust. To fit those 88mm thick-wall cylinders, the heads must be machined for the larger cylinder diameter. These are the ones, whereby they might not be easily available in your country- http://vwparts.aircooled.net/Piston-Cylinder-Set-88mm-x-69mm-Slip-In-p/vw8800t1k.htm
If you do not want to fit the larger cylinders and do no machining to the heads, then you can get standard 1600cc type 85.5 pistons/cylinders. Those will properly fit into your case openings. Can you trade your new BB 83's for a set of stock ones for 1600 engines?
Glutamodo- is this a feasible plan for him? |
