"HELP" SMOKING engine
Jefropi
Jefropi is offline
PostPosted: Tue May 26, 2015 11:31 am    Post subject: "HELP" SMOKING engine Reply with quote
Hello,
I am new tu VWs. I have a 1970 standard I just put in a new tranny in my car and had to change the pressure plate to match. Runs ok and drives ok. Here is my issue. After driving it to work this morning i noticed that smoke was coming from the engine compartment. I got to work and opened the lid. I seen that there was alot of smoke coming from behind of the engine :Bell housing". So my question is where might the smoke be coming from? Could it be an issue with the tranny or clutch? My clutch cable is a little short. Could that cause an issue? Any help would be appreciated.
Jefropi
Jefropi is offline
PostPosted: Tue May 26, 2015 9:25 pm    Post subject: Reply with quote
So after some looking it seems like the smoke is from oil coming out of both valve covers and dripping on the heater box. Now my question is I think my car is running hot and milted or broke the gasket in the covers. Does this sound like it could be what is causing the leeks? Thanks.
awreed
awreed is offline
PostPosted: Tue May 26, 2015 9:37 pm    Post subject: Reply with quote
Wait, wait ,wait. Your clutch cable is a little short? Is your clutch slipping? You're gonna go through quite a few clutches like that. You should have 3/4" to 1" of free play in the pedal. might wanna check that and get the right clutch.
As far as oil leaking from the valve covers, that isn't a sign of overheating. Rather, it's a sign that you need new valve cover gaskets. Throw away those crappy rubber or composite gaskets and get the cork ones.
Are you using bolt on EMPI valve covers? I bought those once and they ALWAYS leaked on me. Now I only use the stock valve covers with the bails. Never had a leak and I never buy new gaskets.
Danwvw
Danwvw is offline
PostPosted: Tue May 26, 2015 10:29 pm    Post subject: Reply with quote
2X on "awreed" post and make sure you've put the right clutch in your car they changed between 70-71. If you go with a 71 trans then your going to need a different clutch. http://vwparts.aircooled.net/200mm-Kennedy-Engineering-Racing-Pressure-Plates-p/kep-200mm.htm
As far as oil dripping on your heater boxes it is a hazard that happens sooner or later to all of us. When it happens to me I clean them out with a non flammable brake cleaner or some spray can stuff. Get the cheapest you can find and used a couple or even 3 or four cans of the stuff get all that oil out of your heaters so it does not smell bad inside the car when the heaters are turned on. Don't turn on the heaters until it's baked out either.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Jefropi
Jefropi is offline
PostPosted: Wed May 27, 2015 7:16 pm    Post subject: Reply with quote
The newer tranny has the longer arm thing with this seems like the cable is short. I can get the nut on but barely. I was thinking that the clutch as not releasing all the way causing the smoke. But now i see its from the covers. Here is the issue tho. It never leaked till i removed the engine and out it back in. I did drive it around with the with the motor tins off. I read that it could cause it to overheat and leaking gaskets were a symptom.
Cusser
Cusser is offline
PostPosted: Wed May 27, 2015 7:54 pm    Post subject: Reply with quote
You drove it around with the "motor tins" off ????? What made you think that was a good idea ??? You have this great forum here and you never bothered to post such a silly query ???
sjbartnik
sjbartnik is offline
PostPosted: Wed May 27, 2015 7:57 pm    Post subject: Reply with quote
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Jefropi
Jefropi is offline
PostPosted: Wed May 27, 2015 8:04 pm    Post subject: Reply with quote
I was not thinking... So did i mess up the motor? It still runs good.
sjbartnik
PostPosted: Wed May 27, 2015 8:15 pm    Post subject: Reply with quote
I don't know. Fix your valve cover gasket oil leak, get back to us with valve lash numbers and compression numbers and let's see.
2000 Kawasaki W650
Bob Brugge
Bob Brugge is offline
PostPosted: Fri May 29, 2015 2:34 pm    Post subject: Reply with quote
sjbartnik wrote:
LMAO!!! Again!!
Jefropi
Jefropi is offline
PostPosted: Sun May 31, 2015 7:47 pm    Post subject: Reply with quote
Hay cmon im a new to vws had no idea they were for cooling. Thought it was for keeping road grime out of engine compartment. It was just a test drive.
Air-Cooled Head
Air-Cooled Head is offline
PostPosted: Mon Jun 01, 2015 9:20 am    Post subject: Reply with quote
Don't take it too seriously. The Samba is a rough room to work. Laughing
Lots of smart people here, who are often good-natured smart asses too. Very Happy
I doubt you ruined your motor with a test drive. As long as it wasn't a 2 hour test drive, at speeds approaching 90. Shocked
DO get a Bentley manual for your car.
DON'T be afraid to ask. There's even a Stupid Question thread, for when you need to ask "What are the engines tins for?"
I went back and read your older posts. Right now, it seems you're stumbling around, and I fear you may become frustrated and quit. You need to make a few VW friends, which shouldn't be too hard since you live in Cali. With a little help from your friends, you'll begin to really enjoy your VW.
Good Luck!
Everything known to man has been written.
Readers are Leaders!
TheAmazingDave
TheAmazingDave is offline
PostPosted: Mon Jun 01, 2015 9:59 am    Post subject: Reply with quote
Where in Cali are you? If you're in the SF South Bay, I'd be happy to take a look. I'm by no means an ACVW expert, but I know my way around and have been working on cars for a long while now.
Just call me Big D. (formerly xBigDx408x)
TheAmazingDave.net
Deutschland Dubs 2015 at Presidio Trust
Jefropi
Jefropi is offline
PostPosted: Tue Jun 02, 2015 6:27 pm    Post subject: Reply with quote
Thanks I live in Auburn north of Sacramento. The car does not smoke that much anymore but does run very hot. Cant touch the dipstick.
Jefropi
Jefropi is offline
PostPosted: Tue Jun 02, 2015 6:30 pm    Post subject: Reply with quote
My nex question is how do i tell if the fan vent is open on the motor? When i took the motor out I forgot to check this. Is there an easy way to find out?
