OregonMGReplica52 Samba Member
Posted: Tue May 26, 2015 2:55 pm Post subject: 1972 1600... which distributor? |
I have a 1972 vw 1600 with a dual barrel holly carb on it. Would a 009 or a vacuum distributor work best for my engine? thank you! |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
Posted: Tue May 26, 2015 3:53 pm Post subject: Re: 1972 1600... which distributor? |
OregonMGReplica52 wrote: |
Do you mean a Holley bug spray? A german 009 should work. _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76943 Location: Sneaking up behind you
Posted: Tue May 26, 2015 3:59 pm Post subject: |
My guess is a Weber Progressive. _________________ Glenn
Member #1009
#BlueSquare |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue May 26, 2015 6:55 pm Post subject: |
In any case, when you start moving away from the stock carburetor you are limiting your choice of distributors since the vacuum distributors need the correct signal from the carburetor in order to work as designed. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
