vwfye Samba Member
Posted: Thu Jun 18, 2015 10:35 pm Post subject: |
If I had hair, I would have pulled it all out tonight!
I back track... Today I drove down to Grants Pass, happy to be picking up some calipers from a friend. Got back and waited for the evening breeze and got the caliper off the car, unhooked the hose and installed the new hose to the hard line. Then, I grabbed the new to me caliper and realized it was an early unit. So... On I push and hook up the old caliper to the new brake line. No bueno! It is definitely the caliper that is the issue.
Anyone have a late caliper they would part with? I'll trade ya two earlies! I need this car driving... augh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Jun 19, 2015 8:20 am Post subject: |
$100/pair _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Erik G Samba Member
Joined: October 16, 2002 Posts: 13271 Location: Tejas!
vwfye Samba Member
Posted: Fri Jun 19, 2015 9:57 am Post subject: |
Do you have a link? Every time I look, it is for the earlier caliper up to mid 1970.
Thanks! _________________ 64 No'back Speedster "Pearl"
Erik G Samba Member
Posted: Fri Jun 19, 2015 10:08 am Post subject: |
unfortunately, one of the things about rock auto is that there are no links...
here's whats listed for 72-73 only
when you go to rockauto, use the blue part number search with these part numbers.
_________________ Stop dead photo links! Post your photos to The Samba Gallery! |
vwfye Samba Member
Posted: Fri Jun 19, 2015 11:12 am Post subject: |
Thank you! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Fri Jun 19, 2015 6:21 pm Post subject: |
Mike Fisher wrote: |
$100/pair |
You always kick a guy when he is down? _________________ 64 No'back Speedster "Pearl"
Posted: Fri Jun 19, 2015 9:11 pm Post subject: |
If you can't afford 4 VW's then sell a couple of them so you have money for the others. _________________ https://imgur.com/user/FisherSquareback/posts
vwfye Samba Member
Posted: Fri Jun 19, 2015 9:32 pm Post subject: |
Pulled the caliper and pulled the pads. Reinstalled and filled reservoir. Proceeded to pump the crap out of the brakes to see if the piston would pop. No luck. The inner is frozen solid. _________________ 64 No'back Speedster "Pearl"
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Fri Jun 19, 2015 9:37 pm Post subject: |
vwfye wrote: |
Pulled the caliper and pulled the pads. Reinstalled and filled reservoir. Proceeded to pump the crap out of the brakes to see if the piston would pop. No luck. The inner is frozen solid. |
Keep the outer pad in place. Only remove the inner pad so that all of the pressure in on the inner piston. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Fri Jun 19, 2015 9:40 pm Post subject: |
Tried that too. Stuck! I'm not wanting to pull the unit apart, but that seems to be next. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sat Jun 20, 2015 8:40 pm Post subject: |
Wow.. been an up and down day. I've put 500 miles on the truck chasing calipers. I now have 3 units to build 1 good one out of. So, hopefully, soon I will be driving this car. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun Jun 21, 2015 8:13 pm Post subject: |
Match. Meet car. _________________ 64 No'back Speedster "Pearl"
Posted: Sun Jun 21, 2015 8:20 pm Post subject: |
vwfye wrote: |
Match. Meet car. |
When are you coming up this way next? bring me a caliper... _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Sun Jun 21, 2015 8:25 pm Post subject: |
It isnt just that Tram... the extra pump I have; same leak. Grrrr! _________________ 64 No'back Speedster "Pearl"
Posted: Sun Jun 21, 2015 8:27 pm Post subject: |
vwfye wrote: |
It isnt just that Tram... the extra pump I have; same leak. Grrrr! |
Does it work OK otherwise? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Sun Jun 21, 2015 9:39 pm Post subject: |
yes... just like the one on the car... _________________ 64 No'back Speedster "Pearl"
Posted: Sun Jun 21, 2015 9:40 pm Post subject: |
vwfye wrote: |
yes... just like the one on the car... |
Dry it off and scuff the joint with sandpaper. Apply JB weld and let it sit overnight. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Sun Jun 21, 2015 9:46 pm Post subject: |
I didn't think JB was fuel compatible... I'll give 'er a whirl! _________________ 64 No'back Speedster "Pearl"
Posted: Sun Jun 21, 2015 10:32 pm Post subject: |
vwfye wrote: |
I didn't think JB was fuel compatible... I'll give 'er a whirl! |
Not affected bu gasoline when fully cured. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
