richardc Samba Member
Joined: September 06, 2010 Posts: 269 Location: New Jersey & North Carolina
Posted: Fri May 29, 2015 9:09 am Post subject: upper balljoint orientation |
Replacing upper balljoints that have been replaced before. There no dimples in torsion arm, but chisel marks. ( I used a grinder to accent the marks) but is that the correct orientation of b/js into arms?
_________________ 1970 Ghia vert
1970 Beetle sedan |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri May 29, 2015 9:13 am Post subject: |
visualize how the front end travel works and you will have your answer
in other another word, yes _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Fri May 29, 2015 9:19 am Post subject: |
Thanks Rick, was 99% sure it was but...... _________________ 1970 Ghia vert
1970 Beetle sedan |
jsnwelch Samba Member
Joined: October 30, 2013 Posts: 86 Location: Bethalto, Illinois
Posted: Fri May 29, 2015 9:25 am Post subject: |
On some of the newer ball joints, it doesn't matter. The ones I just put on mine, they didn't have any of the indents for orientation, but the stud on the ball joint could move equally free in any direction, unlike the stock ones where they can really only move back and forth because of the way they are slotted. I got my new ones from O'reilly's, they were their Direct Import brand, but when I got them out of the box they were actually Febi/Bilstein. |
Posted: Fri May 29, 2015 9:29 am Post subject: |
I'd like to see a picture of those _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Fri May 29, 2015 9:31 am Post subject: |
They're installed in the car, or I'd take a picture. It was aligned with no problems and drives fine though. I even did a search of the part numbers, and they checked out. |
shakers73 Samba Member
Joined: June 14, 2011 Posts: 820 Location: Saltville, Va
Posted: Sat Mar 19, 2022 6:54 pm Post subject: |
jsnwelch wrote: |
I recently got some from Wolfsburg West. They too, were Febi/Bilstein joints and the uppers are non directional(they turn in all directions). The lowers, also Febi/Bilstein, had the directional notches on them. _________________ shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish. |
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Sat Mar 19, 2022 7:06 pm Post subject: Re: upper balljoint orientation |
I suspect that the non-directional ball joints would either have less range of motion, or be weaker due to less material. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Mar 19, 2022 7:26 pm Post subject: Re: upper balljoint orientation |
TDCTDI wrote: |
I suspect that the non-directional ball joints would either have less range of motion, or be weaker due to less material. |
Actually, they have more range of motion. Where the directional move only north and south, the non-directional travel in all directions, much like modern vehicle ball joints. _________________ shakers73
'74 Super Beetle
'67 Beetle
Posted: Sun Mar 20, 2022 6:59 am Post subject: Re: upper balljoint orientation |
shakers73 wrote: |
TDCTDI wrote: |
Actually, they have more range of motion. Where the directional move only north and south, the non-directional travel in all directions, much like modern vehicle ball joints. |
Umm, the design of the suspension means that, unless something has gone very wrong, the ball joints will NEVER move any direction than the “north/south” orientation that the original ball joint design.
Not that this is acceptable at all…
https://youtube.com/shorts/wr9N0P3__yQ?feature=share
But this ball joint would have failed catastrophically long before it got to this point had it been one of the newer non-directional ball joints. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
