TheStanfordWagen Samba Member
Joined: October 06, 2013 Posts: 99 Location: Dresden, Ohio United States
Posted: Fri May 29, 2015 8:04 pm Post subject: Angled shifter? |
Is it possible to remove the protruding bar from the ball of the early style shifters for use with the later style shift rod receiver that isn't slotted? Has anyone done this?
I really would like to have the angled shifter as opposed to the straight shifter.\\ _________________ 1968 Type 1 - Royal Red --- Built: September, 1967
1600 Single Port Engine - F1950480 (VW Exchange) Made January 16th, 1970
113-905-205K
Solex 30 PICT-3
Fahrgest.-Nr. 118096544 |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Fri May 29, 2015 8:07 pm Post subject: |
If you use a stock angled shifter, I believe you need a shift rod that has the slot in the cup.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Fri May 29, 2015 8:25 pm Post subject: |
If you remove the locating pin from the curved shifter you will have nothing to keep the shifter from rotating. What you instead need to do is cut a slot for the pin into the shift rod cup so the curved shifter cannot rotate. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Fri May 29, 2015 8:30 pm Post subject: |
I will do that. Thanks! _________________ 1968 Type 1 - Royal Red --- Built: September, 1967
113-905-205K
Solex 30 PICT-3
