kgj Samba Member
Joined: February 25, 2013 Posts: 418 Location: Uk, Cornwall
Posted: Mon Apr 18, 2016 11:54 pm Post subject: Re: Why do we start these things? |
You are probably right. I did rock it back and forward over the pit a bit but probably not enough to make a difference.I have also not refitted the shocks at this point, just dropped it off the jack to have a look. So probably just back at the start point.
Thanks for looking. _________________ 1958 coupe |
kgj Samba Member
Posted: Wed Apr 20, 2016 1:50 pm Post subject: Re: Why do we start these things? |
A lot of effort for not much gain. As low as it will go without resting on the bump stops.
5 inner spline turns and wherever outer splines fell best.
Also installed an EMPI anti roll bar.
What an amazing difference that makes to cornering! Well recommended for anyone thinking of getting one.
And ready to drive home from work.
scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
kgj Samba Member
Posted: Wed Apr 20, 2016 2:39 pm Post subject: Re: Why do we start these things? |
Thanks for the tip Mr Timmerman. I was wondering if there was scope to cut the bump stops down and you have confirmed it for me. I'll get it over the pit again tomorrow and get the hacksaw out.... _________________ 1958 coupe |
carl4x4 Samba Member
Joined: March 20, 2012 Posts: 679 Location: United Kingdom
Posted: Thu Apr 21, 2016 6:05 am Post subject: Re: Why do we start these things? |
Lot's of good work here, I've also fitted a rear anti roll bar recently but not got the car back on the road yet to try it out. I also fitted a Kafer-bar brace between the shock towers and the frame forks so I'm hoping the back end will all be significantly stiffer. The rear was always a little too loose compared to the front in my book. Good to hear positive feedback on the rear bar. _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
kgj Samba Member
Posted: Thu Apr 21, 2016 10:14 am Post subject: Re: Why do we start these things? |
I'll be interested to get your thoughts on the brace too.
It turns out my first impressions of the anti roll bar were tainted by the suspension resting on the bump stops!
So as advised
I cut them down and re fitted.
Definitely got travel now.
And fortunately it still feels as good.
And this is where it all settles out at. 506mm (-36mm )
Next job, 4 wheel alignment to make sure all is as it should be.
Posted: Fri Apr 22, 2016 9:52 am Post subject: Re: Why do we start these things? |
kgj wrote: |
good idea on the alignment, IRS seems really sensitive to rear toe settings, mine was toe-out and drove very strange! _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
kgj Samba Member
Posted: Fri Apr 22, 2016 1:11 pm Post subject: Re: Why do we start these things? |
Yes, I have an obsession with tracking. Even a minor adjustment can make the difference between a car that drives horribly and one that drives like a dream. At the moment it drives ok but there is this place near me that does 4 wheel computer based tracking and it would be good to see the stats now she's lower front and rear.
Looks much better now though, in my opinion.
kgj Samba Member
Posted: Sun Apr 24, 2016 2:03 pm Post subject: Re: Why do we start these things? |
Haven't had the tracking done yet but a sunny weekend and 60 miles driven, mostly on dual carriageways and A roads
And it feels wonderfully planted, especially on the bends, If a bit noisy compared to a modern.
One problem,
Ground clearance for my EMPI exhaust. Caught it a couple of times on speed bumps and nearly got stuck on a mates steep drive requiring driving on a plank to make enough clearance to get back out!
I've got an idea for a mod though.
Clearance from road to flange
Is 110mm.
Road to exhaust box is
85mm. And it's further back making the difference worse than 25mm.
Tomorrow, I'm going to see if I can get the bit of pipe joining exhaust box to flange modified to give better road clearance. Get the box up above the flange it it should be fine to live with.
kgj Samba Member
Posted: Tue Apr 26, 2016 7:18 am Post subject: Re: Why do we start these things? |
This at least has gone to plan.
Before.
And after.
2 cuts and weld. Not me, a more talented person. I think it all lines up a lot better than before. And with added road clearance.
kgj Samba Member
Posted: Thu Aug 11, 2016 3:38 pm Post subject: Re: Why do we start these things? |
So one year later and she's in the air again. Hopefully for the last time in my ownership, for the last bit of remedial attention needed. New heater channel, rocker and quarter panels on the right hand side. Fortunately only needed because the back end of the heater channel on this side was a bit ropey, this side generally is a lot better than the other side I tackled last year.
I've been here before so progress has been quite rapid by my standards, 3 weeks of a few hours here and there has got me to this stage. Heater channel installed, rocker nearly finished.
A bit of work still to go on the back end where a PO has had the rear quarter "repaired" before but only with flat plate and no return on the inner part connecting to the outer skin.
I'm planning on a freshen up of the paint once this is done then maybe sell it on next year to fund the lowlight? Who knows? The MOT is due to run out on September 1st so I need this finished and roadworthy ASAP to enjoy some late summer motoring.
kgj Samba Member
Posted: Sat Aug 27, 2016 2:50 pm Post subject: Re: Why do we start these things? |
Update for my own amusement.
Rebuilt rear quarter all sealed up
Most pleasing moment of this little project has been the removal of the original front quarter without wrecking it, and then reusing it instead of a new repair panel I bought.
Another little job that has been waiting to be done. Replace the old tar boards with some sound deadening stuff I bought ages ago.
Back on the road tomorrow.
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
kgj Samba Member
Posted: Sun Aug 28, 2016 12:22 am Post subject: Re: Why do we start these things? |
Thanks mate. And nice thread yourself. I follow with keen interest along with many others on here. You are Mr Detail!
Woke up this morning to pouring rain! Not forecast.
A couple of friends of mine are throwing a party tonight at their place 20 miles away to celebrate their 25th wedding anniversary. Taking the Ghia has been my deadline for the last few weeks. Should be dry outside by then. _________________ 1958 coupe |
kgj Samba Member
Posted: Mon Aug 29, 2016 5:54 am Post subject: Re: Why do we start these things? |
Back on the road again. Just in time for Bank holiday weekend motoring adventures.
On the coast road in Poldark country. 100 mile round trip to a mates anniversary party
They call this place Hells Mouth.
Stopped by another mates place on the way. As if reviving a 50's Morris Minor wasn't enough...
He's just picked up a Capri to get stuck into too. One at a time mate!
And here is the Ghia at journeys end with new friends. MGC (2.9 straight 6). Quite rare I believe. And a Morgan 3 wheeler.
Did you know that when you rev up the Morgan's air cooled twin the exhausts glow. How cool is that!
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
kgj Samba Member
Posted: Wed Aug 31, 2016 3:00 pm Post subject: Re: Why do we start these things? |
Mk1 razor edge Capri.
Happy day. Speedo is about 10mph out. I uploaded a speedometer app to make a comparison. I'm not alone with this I read on here.
The open road, sunshine and sea. Not all at the same time though.
A note about shrinkage. Both of my rear quarters had been "repaired" before and both had been shrunk badly. Looked OK side on but looking down the panel looked like this.
I'm no expert but even I have noticed panel warp as you weld if you are not too careful. Looks awful and would need loads of filler to straighten out. See how this panel is pulled in. And this is with filler!
Here is my after photo. No filler, just some mat black over some primer.
My limited experience is, keep the panel cool. Just a spot of weld at a time. And try the trim pieces often. Flatten the welds with a dolly behind as best you can. Build the welds up slowly.
MOT tomorrow.
Thanks for looking _________________ 1958 coupe |
kgj Samba Member
Posted: Mon Oct 03, 2016 7:27 am Post subject: Re: Why do we start these things? |
Ongoing update. Now the last bit of metal needing attention has been replaced the time has come to get some shiny black paint back on all the affected areas. I have decided to get most of the car repainted save for hood and engine bay areas. The engine bay was done last year when the engine was refitted. So a weekend spent taking everything off and out.
It was a bit of a draughty drive to the body shop with no glass in the car but at least it was only a mile or so up the road near where I work. The body shop think they will be done in a couple of weeks. And because it's so close to where I work I will be able to pop round at lunch times and check progress.
Chochobeef Samba Member
Joined: May 01, 2013 Posts: 811 Location: Ft. Worth, Texas
Posted: Mon Oct 03, 2016 9:51 am Post subject: Re: Why do we start these things? |
Nice work. Keep up the updates. Should take a picture of your daily and ghia together when its ready.
On a side note, is your generator clocked correctly? It looked off to me? |
kgj Samba Member
Posted: Mon Oct 03, 2016 12:16 pm Post subject: Re: Why do we start these things? |
Quote
"Should take a picture of your daily and ghia together when its ready."
OK, will do As soon as this one is rolling again.
Quote
"On a side note, is your generator clocked correctly? It looked off to me?"
Would love to answer that one but I'm not sure what that means. What do I need to do?
Thanks for looking though.
And how do you do that quote thing properly? _________________ 1958 coupe |
