CAlex Samba Member
Joined: March 07, 2015 Posts: 100 Location: Orlando,Fl
Posted: Sun Jun 07, 2015 7:34 am Post subject: German door handles? |
Can anyone out there give me some accurate info on my '65 bug.Need to know if the door handles come with a key hole only on the drivers side?or both doors come with key?Going to buy a whole set of German made door handles with key but it only comes with driver's side key,passenger side has no key hole.are these real German made?thanks to all.. |
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 513 Location: Shoreline, WA
h~moto Samba Member
Joined: November 19, 2008 Posts: 317 Location: Northern Virginia
Posted: Sun Jul 05, 2015 2:52 pm Post subject: |
Both should have a key if they are for a Beetle intended for the US market. Euro spec Beetles did not have a key slot on the passenger side. |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sun Jul 05, 2015 6:58 pm Post subject: |
Basically as h~moto say's, if your car is a stock unaltered US market '65, then yes both front doors should have handles that lock/unlock the latch from outside with the same key as Ignition.
They have square buttons and have a paddle on the end of the lock cylinder that activates the latches to locked/unlocked positions looking exactly like the square button ones pictured in Mr. Mike's link...
https://www.thesamba.com/vw/classifieds/pix/3867155.jpg
How to ID Original German? AFAIK they may not be marked with country of origin. Some things to look for and/or avoid:
Original VW door handle/lock vendors were Huf and AKS, so look for either of these two logos cast into the bases somewhere.
Note the key shape in the above linked reference photo. Original handles will have cylinders that use this type of key blank, and three distinct and proprietary profiles, SC,SU or SV. The profile and code number set will be stamped into the handle base assembly...
http://www.thesamba.com/vw/forum/viewtopic.php?t=497431&highlight=key+code
Original base material is a white metal alloy that turns darker as it ages and steel parts that are plain or silver cad plated.
-Low cost Re-pops have a brand new shiny look, poor polish, thin chrome and some have yellow anodized steel parts.
Hope this helps _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
