NewTechnicIan Samba Member
Joined: May 28, 2013 Posts: 367 Location: Burlington, VT
Posted: Sun Jun 07, 2015 12:55 pm Post subject: Bug Luggage Tray Pinholes |
Hey all,
Just got my bug sandblasted and epoxy primed (WOOOO!)
It looks great for the most part, aside from a new issues that came up. I thought I had done some good welding and sealing up of some pinholes on my luggage tray, but sandblasting brought out a good few more pinholes than I thought.
Check out the damage:
There's pinholes and bigger than pinholes. I don't see repairing all that any other way than welding in a new floor section, but I can't find any sections of just the floor and shipping the whole section is Stupid Expensive.
I'm gonna post a Wanted Ad to the classifieds and see if I can find a panel, but:
Can I sand the epoxy, cover the holes in filler, and prime, paint, undercoat over all of this and trust it to hold up for a restoration
That's the one big problem area after sandblasting, otherwise I'm psyched to start filler and bodywork and get this thing ready for some high-build primer!
Thanks for your help all! _________________ My 73 Standard build - It's painted! It drives under its own power! Time to get it wired and upholstered!
My 1679 Engine build. |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Mon Jun 08, 2015 7:01 am Post subject: |
That area will be covered/carpeted, no?
For this repair, I'd use fiberglass.
See comment by Dirtkeeper in this thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=628420 _________________ Everything known to man has been written.
Readers are Leaders! |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17969 Location: Eugene, OR
Posted: Mon Jun 08, 2015 7:45 am Post subject: |
MasterSeries silver & black would fill those holes nicely. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Mon Jun 08, 2015 4:23 pm Post subject: |
If you wanted to put a lot of time in it, you could;
-Patch worst areas
-Solder and or lead the deep pits.
Soldering pin holes is a good method, cheap and easy. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
green1303 Samba Member
Joined: February 04, 2014 Posts: 748 Location: Alexandria, VA
beetlenut Samba Member
Posted: Mon Jun 15, 2015 2:18 pm Post subject: |
Hey Ian,
Looks good! I've heard of people putting masking tape on the bottom of those holes and then use multiple layers of either Master Series Silver primer, or POR-15 patch. The MS has levelers that fill in low spots. The POR-15 patch comes in a tube and is thicker like toothpaste. The both harden solid and can then be painted over.
Bill _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
oldmanmark Samba Member
Joined: July 08, 2006 Posts: 842 Location: n.w. indiana,chicagoland
Posted: Wed Jul 08, 2015 6:51 pm Post subject: |
Doesn't look that bad from your pics. Its a matter of how much effort n time to satisfy yourself. I'd cut out the big holes and weld in new metal. Like Mike said master series work good on pin holes. U got good advice. If its covered up,easier to solve. |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sat Jul 11, 2015 8:00 pm Post subject: |
If structurally it feels strong. I would get some fiberglass reinforced filler and put that on there. Duraglass or something like that. Its strong and waterproof. Be warned though. It can be a bear to sand when dry. Especially on a surface like that. I would get some mechanic gloves and some 36 grit ready to go. Once the Duraglass starts to kick, get after it and get it shaped or close before it gets to be like concrete! |
johneliot Samba Member
Joined: August 29, 2005 Posts: 2189 Location: Chico, CA
Posted: Sun Jul 12, 2015 7:42 pm Post subject: |
I had holes similar to those. I use some fiberglass pieces soak in Master Series and put over the holes. When it dried, I painted another coat. It will dried rock solid and water tight. This is the only picture I have. You can see a few covered up holes.
_________________ John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost" |
