Sudar Samba Member
Joined: May 18, 2015 Posts: 33 Location: Stewartstown, PA
Posted: Wed Jun 17, 2015 2:42 pm Post subject: Rate my floor pan rust! |
So I knew the driver's side floor pans had some rust. I pulled the seat and carpet and here's what I found.
Looks like PO did a patch on the front section
Behind driver's seat is the worst, there's some kind of putty in there closing a hole through the pan. There is a lot of undercoating under the car in this area.
under rear seat
Seat rails and frame look pretty good from this view.
On a scale from 1 to 10, 10 being worst, How would you rate this rust?
Recommendations on what I should do to fix it is appreciated. A full refurb is a long way off so I'm thinking patching.
Thanks,
Darrin _________________ 1968 Ghia Coupe AKA "Harley"
1969 Beetle Standard AKA "Angus" |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Wed Jun 17, 2015 4:01 pm Post subject: |
On a 1-10 scale, I'd call that 3, maybe 4.
The last pic, by the heater cable, 5. _________________ Everything known to man has been written.
Readers are Leaders! |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Wed Jun 17, 2015 6:47 pm Post subject: |
Scrub with a wire brush, vacuum out the loose stuff, then paint it with Rustoleum ... rusty metal primer then paint.
Then figure out where the water is getting in. How are the window seals? _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
