DBUG Nist Samba Member
Joined: April 24, 2015 Posts: 62 Location: Akron Ohio
Posted: Thu Jul 09, 2015 1:59 pm Post subject: |
I was mistaken the fan is a single speed and yellow/Red and White/Blue are the same so can i just use 1 set and cut the other it wouldnt make a difference right?
Also am i able to reduce the size of the fuel line somehow because the e2000 pump has an 5/6's inlet and outlet and the fuel filter is 5/16's? _________________ 2011 sentra (dd)
1970 type 1 rail buggy,soon to be the bugaru
dansvans wrote: |
heres an idea:
you give Empi your money and they punish you for it. common scenario. |
Posted: Sat Jul 11, 2015 12:15 pm Post subject: |
scratch the fuel pump question i bought it and its perfect size, also do i need KEP's throw out bearing or does the stock one work sufficient enough? _________________ 2011 sentra (dd)
dansvans wrote: |
heres an idea:
no1clyde Samba Member
Joined: August 27, 2013 Posts: 365 Location: Elko Nv.
Posted: Sat Jul 11, 2015 1:14 pm Post subject: |
Great on your pump. I have used 2 KEP kits, one in my Baja and the other in my buggy and I used the stock throw out bearing in both of them.
Here is a very short video of my Subaru running yesterday https://www.youtube.com/watch?v=Ln3_rIVRK3U&feature=youtu.be
Ed |
Posted: Sat Jul 11, 2015 2:28 pm Post subject: |
alright cool another thing to save some money on but nice glad to see it running! are you going to make another video of it running and driving because im really looking forward to that, it also sounds pretty quiet _________________ 2011 sentra (dd)
dansvans wrote: |
heres an idea:
Posted: Sat Jul 11, 2015 3:19 pm Post subject: |
I may but it is a long way from driving. I want it to be quiet, in the end I want it to be my DD.
Ed |
Posted: Mon Jul 13, 2015 10:52 am Post subject: |
that would be one heck of a dd thats forsure
I hope my adapting kit will be here today so i can finally mount up the engine and start laying out the harness to test to see if the harness is good and it turns on then start figuring out exhaust routing and everything else.
i welded up a bracket or the bottom pins of the radiator (im a terrible welder and this is the third time welding with a stick welder but its solid and not breaking or moving anywhere!
dustin _________________ 2011 sentra (dd)
dansvans wrote: |
heres an idea:
Posted: Tue Jul 14, 2015 12:20 pm Post subject: |
Its finally here!! Any Advice on putting it on? do i need the dowels from the original transmission, because they ended up getting stuck in the trans and wouldnt come out.
-Dustin _________________ 2011 sentra (dd)
dansvans wrote: |
heres an idea:
Posted: Tue Jul 14, 2015 7:27 pm Post subject: |
If the adaptor plate has holes for the dowel pins I would try to find some, I forget when I put mine together. One thing with your transmission mount you will be losing ground clearance and you may want to cut the pan down some. I put my motor in at a 15* angle to raise the pan. Good luck on it and the wiring. I actually made mine move under its own power today by hooking up the clutch and putting it in gear and pushing in the clutch and starting it and letting the clutch out and we moved LOL.
ED |
Posted: Wed Jul 15, 2015 7:55 am Post subject: |
i hear i might be able to punch them out through the opposite side of the trans so i might give that a try. how did you manage to add a 15* angle to it? hahah so you basically did a little bump start and thanks hopefully it starts up like i hope it does i believe i have everything hooked up right. does your vw starter have enough torque to start it, i hear mixed options. If it helps mines basically brand new out of the box _________________ 2011 sentra (dd)
dansvans wrote: |
heres an idea:
Posted: Wed Jul 15, 2015 8:45 am Post subject: |
I built all new motor and trans mounts to tip the back of the motor up. I have a new rebuilt starter and with good battery cables it cranks fine but with crappy jumper cables it didn't.
Ed |
Posted: Wed Jul 15, 2015 10:27 am Post subject: |
alright good so my starter should work just fine then. i got the dowel pins out and put them in the motor. anywhere i can buy an shortened oil pan because if i tried to do it myself i would mess it up and id rather not do that hah. _________________ 2011 sentra (dd)
dansvans wrote: |
heres an idea:
Posted: Wed Jul 15, 2015 10:53 am Post subject: |
OHH quick question ed what did you do for the water temp sensor (single wire, not two) did you use your stock VW gauges or did you go after market because i'm having a hell of a time trying to find the right after market one for a gauge. My VDO sender was to big and this other one ( summit racing sender or similar it was just laying around) it fit but the threads didn't and i wasn't about to strip anything to find out. _________________ 2011 sentra (dd)
dansvans wrote: |
heres an idea:
Posted: Wed Jul 15, 2015 12:25 pm Post subject: |
I don't have any gauges yet so I just have the stock sender in there to plug the hole. Right now the only things on my dash are the key switch that is a universal one and 3 idiot lights, oil pressure, alternator and check engine lights.
Ed |
Posted: Wed Jul 15, 2015 6:50 pm Post subject: |
ed did you by chance have locating dowels on the flywheel? similar to the ones for the engine to trans but its for the pressure plate to the flywheel _________________ 2011 sentra (dd)
dansvans wrote: |
heres an idea:
Posted: Wed Jul 15, 2015 8:21 pm Post subject: |
No just the bolts as I remember.
Ed |
Posted: Fri Jul 17, 2015 9:50 pm Post subject: |
adapter plate is on
its looks like i might have some fair clearance for the oil pan, i wont take it off road until it has a shortened pan, but it is street legal so i can drive it on the street no problem.
and made a cartoon style stencil really quick for the heck of it sprayed it with 2 very light coats so it wont effect cooling.
dansvans wrote: |
heres an idea:
Posted: Mon Jul 20, 2015 4:51 pm Post subject: |
I doubt they did any legacy come with an immobilizer before the year 2000? _________________ 2011 sentra (dd)
dansvans wrote: |
heres an idea:
Posted: Mon Jul 20, 2015 6:52 pm Post subject: |
Don't know about OBD2 Subarus but my 2000 Toyota OBD2 that is in my buggy did not have any.
Ed |
Posted: Mon Jul 20, 2015 8:35 pm Post subject: |
nice, well no one else seemed to have ran into that problem with the older models and the boxerswaps.com write up for the 95 didn't mention anything about it so i have a feeling i'll be fine Also while checking out some of the stuff on shoptalk forums i noticed them talking about the stinger stand alone setup which seemed interesting. My main question is do i need a fuel surge tank? is it really needed on a basic stock setup, regardless are there benefits? _________________ 2011 sentra (dd)
dansvans wrote: |
heres an idea:
thesatelliteguy Samba Member
Joined: January 06, 2007 Posts: 1515 Location: Santa Rosa CA
Posted: Mon Jul 20, 2015 8:37 pm Post subject: |
Dam this brings back memories!
I did the Subi engine swap in my baja about a year and a half ago. I havent looked back, well other to see the rice burners slowly disapearing in the rear view. _________________ Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878 |
