Ohio_Style Samba Member
Joined: July 09, 2007 Posts: 610 Location: You'll never leave Sparta alive, Ohio
Aerindel Samba Member
Joined: May 30, 2015 Posts: 459 Location: Western Montana
Posted: Sun Jun 21, 2015 8:36 pm Post subject: |
I just bought some pre-made metal ones intended for DIY trailers. They where only $12 a Pacific steel and fit reasonably well. Tube framed ones would be a stronger but these where easy, I bet you could do something similar for Baja.
_________________ Homemade woods/street, bug out rail. IRS, Balljoint front end. 1967 1600cc DP, Weber 32/36 progressive, tri-mil quiet pack. Rear only cutting brakes.
http://www.thesamba.com/vw/forum/viewtopic.php?t=630046 |
terryly Samba Member
Posted: Mon Jun 22, 2015 5:08 am Post subject: |
I made these from 1/2"conduit they do work. Not for everyone but could be skinned on top or on bottom I chose to inset panels. The beauty is in the attachment bracket that allows you to use the stock fender mounting hole. I can take a pic and post if you need I also stole the idea for the bracket from a samba member. It was a brilliant. Saw it once made a mental note then when came time to build could not find it again. Searched forever and even posted a question. Then just muddeld through it from memory
Terry |
HERC Samba Member
Posted: Mon Jun 22, 2015 6:36 am Post subject: |
Damm, those look breasts. _________________ Herc |
Joined: August 31, 2013 Posts: 12850 Location: North Carolina
Posted: Mon Jun 22, 2015 7:02 am Post subject: |
HERC wrote: |
Damm, those look breasts. |
Umm, I think you've been in the garage a little too long :-p |
HERC Samba Member
Posted: Mon Jun 22, 2015 7:08 am Post subject: |
You're right, staring at my motor that needs to go in, as soon as I get some more parts _________________ Herc |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2648 Location: West Coast (Michigan's)
Posted: Mon Jun 22, 2015 9:38 am Post subject: |
I'm plannin on doing this eventually too. It's amazing how quickly the gravel just from dirt roads will erode the front of the rear fenders at 60mph. I have ever enlargening white circles. Not to mention the stress cracks that spell certain impending doom for them.
The EMT conduit IS a good idea. I decided to use it for my roof rack that holds two kayaks and it's stout. Conduit is also very easy to shape with a cheapo electricians' stick. I think I would go with a larger diameter tube though.
I'd be curious to see close up you mounting system if you don't mind Terry. I was going to use just the original fender holes but your's looks a little more involved than that>>>? _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Posted: Mon Jun 22, 2015 2:47 pm Post subject: |
Here is some photos guys. Sorry they are a little dirty. I was out bombing around in Frank on the weekend. The fenders were not enough to keep the windows from getting pasted with mud so added generic mud flaps. Now the front just catches the nerf bar and rear fenders. The rears no longer throw mud on top of the car. If you are beside or behind car you are getting a mud bath HAHAHA
Terry |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5363 Location: Lefty, CA
Posted: Sun Jun 28, 2015 9:10 am Post subject: |
If you are worried about breaking fiberglass fenders think about this: When your Baja makes contact with a tree, something has to give. In the case of fiberglass fenders, they are the weak spot and will crack / break. However, if you make some tubular fenders, they are going to be stronger then the sheet metal body panels they are mounted to. So now instead of breaking a fender, you have crushed in the body panel. For myself, I prefer to stay with fiberglass. It is a lot easier to patch a fiberglass fender, then to pull out a body panel. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Posted: Sun Jun 28, 2015 10:24 pm Post subject: |
I loved the look of my fiberglass fenders. the problem was they were not doing anything with a 6" wider beam and 3x3 rears. Function over form or something like that Here is a better shot of those fenders.
Terry |
