djweaz Samba Member
Joined: October 05, 2014 Posts: 81 Location: Murfreesboro, Tn
Posted: Mon Jun 22, 2015 5:46 pm Post subject: 87mm piston and cylinder need |
So I screwed up and broke the tab off of my brand new piston and cracked the jug. I'm told I have to go with the same brand to keep them in balance. My set are AA brand. Please tell me somebody has something that I don't have to buy a whole nother set just for one. I'm just sick over this.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon Jun 22, 2015 6:11 pm Post subject: |
Contact AA and see about getting a single P&C from them.... _________________ In Stereo, Where Available! |
djweaz Samba Member
Posted: Mon Jun 22, 2015 10:54 pm Post subject: |
I will try that tomorrow thanks |
Posted: Tue Jun 23, 2015 7:10 am Post subject: |
You will need an accurate measurement of the cylinder to get exact size and have to balance the new piston to the other three.
Production of cylinders produces three slightly different sizes. Best to have same size if possible to keep all even. _________________ In Stereo, Where Available! |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
djweaz Samba Member
Posted: Sat Jun 27, 2015 12:20 am Post subject: |
I will try John on Monday AA has never gotten back with me to even say no. I wrote them the other at the beginning of the week. I originally purchased everything for it from Ed at Ed's foreign cars in Gadsen Alabama. Great guy! Very smart very good prices and he knows his VWs. I originally went to him to see if he could do anything. But doesn't have any. Usually he picks them up if the company messed up one of them and then he can sell them in singular form but he has none at this place and time. |
63vbug82 Samba Member
Joined: April 16, 2015 Posts: 146 Location: Cedartown Ga
Posted: Sat Jun 27, 2015 1:44 am Post subject: |
You can try dons buggy stuff also in gadson area very good guy and can get or will help you out as much as he can i do have a mahul pistion and jug if you need pm me for dons number if you need it |
sb001 Samba Member
Posted: Sat Jun 27, 2015 5:38 am Post subject: |
Sorry dj I'd send you one of the AA P/Cs I pulled off my engine when I had it rebuilt but unfortunately they are 85.5. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
eashc Samba Member
Joined: April 10, 2012 Posts: 340 Location: Ventura County
Posted: Sat Jun 27, 2015 8:01 am Post subject: |
Not sure about anyone else, but I want to know what did you do? How did you end up breaking both pieces?
Just curious that's all |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sat Jun 27, 2015 9:32 am Post subject: |
eashc wrote: |
And why is everything so filthy if it is "brand new"? |
Danwvw Samba Member
Posted: Sat Jun 27, 2015 9:57 am Post subject: |
Same Thing happened to me on my last set of AA's! Here is my Post about it: 88mm Slip-in Bottom Machine in top Piston & Cylinders I think the problem happens when one trys to put the pistion rings in from the bottom. "They must go in from the top with the piston removed from the engine!" The New AA's may likely be part of the problem. I got one of these ring compressors and figured out just how to use it, ordered a new single cylinder & piston and got mine on fine!
While your at it "split that case" and clean it up!
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
djweaz Samba Member
Posted: Thu Jul 02, 2015 1:34 pm Post subject: |
When I was installing the first P&C with Ring Compressor that I had it really gave me a lot of difficulty installing with it. I switched to the band that goes around the generator and got them to go on. It was still really difficult to "slide it" into place. I just figured that it was a tighter fit So I tapped it on with a rubber mallet. after I installed the other 3 and they all went on easy(using the VW ring Compressor I ordered) So I went back to the first cylindewr and tried and tried to pull it off even sprayed pb blast and lithium grease. Nothing would get it off so I used the rubber mallet to hit it on the backside which worked so far out. getting behind it didnt leave enough room so I got it out farther and removed the head bolds and put some shop cloths to cusion the hits that the bottom side was being against the block. All went well until the last hit the piston tab broke,. I thought the cylinder was ok but upon closer inspection the piston came out of kilt and broke the bottom of it.
Actually, the new parts are clean. The mess below is because its where took the engine apart with oil spilling out. I got off most of the dirt and crud of being 46 years old before I pulled the old parts off. the additional I didnt want to get inside the block so I was waiting to get it buttoned back off to clean the rest off.
I finally called AA because they never replied to my email. That is already a strike against them in my book. Even if they couldnt do it they could have responded. I will check with John at Aircooled to see if he can come up with anything.
I dont know any names in the VW field for good parts or bad parts. But do to the no response from the email and having to go with a complete set. I might just find another brand to go with.
Sorry for the late responses, I suffer from Rheumatoid Arthritis and dont always get on here everyday or work on my cars if I am hurting to badly |
Danwvw Samba Member
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
