VWAL Samba Member
Posted: Wed Jun 24, 2015 7:08 pm Post subject: 1.6 Turbo Diesel from Japan |
I have a chance to buy a used 1.6 turbo diesel engine/transmission assembly that came from Japan out of a MK II Golf. I have a 1986 Golf 1.6 diesel non-turbo that I might consider this for. Does anybody know what problems I might have with compatibility? I thought of speedometer/speedometer cable issues. I know there are 90mm and 100mm drive axle flanges. If that's different, is it merely a matter of changing axles or does it get more complicated?
Also, I don't know if the exhaust bell is the same. The "new" engine doesn't have the pipe end/bell on it. I've only seen pictures of this engine which makes it harder.
Any other issues?
Thanks. |
madmikeismad Samba Member
Joined: November 10, 2015 Posts: 7 Location: WNY, OKC
Posted: Tue Nov 10, 2015 6:48 pm Post subject: Re: 1.6 Turbo Diesel from Japan |
I don't know much about them, except that all water cooled 4 cylinders will have the same bell housing, and will need a 4cyl trans. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Wed Nov 11, 2015 11:35 am Post subject: Re: 1.6 Turbo Diesel from Japan |
It should be a simple motor swap. You can swap the tranny from/to 90/100mm flanges in minutes. |
oasis Samba Member
Posted: Wed Nov 11, 2015 10:36 pm Post subject: Re: 1.6 Turbo Diesel from Japan |
VWAL wrote: |
I have a chance to buy a used 1.6 turbo diesel engine/transmission assembly that came from Japan out of a MK II Golf. I have a 1986 Golf 1.6 diesel non-turbo that I might consider this for. Does anybody know what problems I might have with compatibility? |
From Japan? Is it right hand drive? _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
artbyedo Samba Member
Joined: November 05, 2015 Posts: 25 Location: Collierville, TN
Posted: Sun Nov 22, 2015 8:58 am Post subject: Re: 1.6 Turbo Diesel from Japan |
I used to own one, here in Japan,
Yes they are right hand drive!
But the engine and transmission are not different at all.
I sourced parts from the U.S. all the time with no issues.
_________________ http://www.artbyedo.com |
