vwbusman66 Samba Member
Joined: May 17, 2014 Posts: 386 Location: Kingsville, MD
Posted: Sat Jun 27, 2015 12:20 pm Post subject: Everything about slider buses |
Hi all, I am looking into buying a 66 slider standard that needs a lot of work. Can someone explain how it works, where parts can be sourced, and what differences are there. Does the door mount at the rocker and side track? Pics would be great.
James _________________ WANTED: Annis Morrill Corp. dealer information and stuff
1958 L53 Pressed Bumper Panel
1973 Wild Westerner
Click to view image |
quartermilecamel Samba Member
Posted: Sat Jun 27, 2015 12:53 pm Post subject: |
My bus is a slider right side door. parts are harder to find but you can find them. PIctures in my gallery _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
velvetgreen Samba Member
orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Sat Jun 27, 2015 6:06 pm Post subject: |
check out my build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=617151
I've had my slider for 10 years.
Its basically the same except for passenger side inner and outer rocker. The out rigger is also different.
What model are you looking at for slider? Panel, standard, deluxe? _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
Posted: Sat Jun 27, 2015 6:07 pm Post subject: |
Standard. Where do you get your metal? Did you fab it? _________________ WANTED: Annis Morrill Corp. dealer information and stuff
1973 Wild Westerner
Posted: Sat Jun 27, 2015 6:11 pm Post subject: |
I saw your thread about your bus! Your bus is far nicer than the one I'm looking at. Its currently listed on the samba _________________ WANTED: Annis Morrill Corp. dealer information and stuff
1973 Wild Westerner
EmpiGT Samba Member
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Sat Jun 27, 2015 6:45 pm Post subject: |
might be easier to turn it into a regular bus _________________ regards
Uli
lightice Samba Member
Posted: Sat Jun 27, 2015 9:14 pm Post subject: |
If the bus is lacking the sliding mechanism, get one with hinged doors. Don't go through the trouble of looking for the sliding mechanism. The cost involved will just make life more difficult in getting the bus running. |
Brw1marine Samba Member
Joined: September 07, 2014 Posts: 67 Location: South Wales UK
Posted: Sun Jun 28, 2015 8:30 am Post subject: |
I agree with Lightice. Sliding doors were a expensive option even when specified new from the factory. Finding parts are a nightmare.
They are just too rare.
Posted: Sun Jun 28, 2015 9:16 am Post subject: |
vwbusman66 wrote: |
Standard. Where do you get your metal? Did you fab it? |
I'll take some picks of the outrigger and jack point I had to modify for the passenger front. The out rigger is much shorter and the jack point had to be trimmed. Other than that the rest of the metal is exactly the same. Besides the door mechanism. Fortunately mine is all intact. _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Posted: Sun Jun 28, 2015 3:23 pm Post subject: |
slider door bottom:
i just removed the out rigger and jackpoint in order to weld in new ones but without everything it looks like this!
outrigger had to modified to fit. It is shorter due to the inner rocker, same with the jackpoint.
Posted: Sun Jun 28, 2015 6:13 pm Post subject: |
Correct me if I'm wrong, but aren't there special latches used on slider buses too?
1973 Wild Westerner
Posted: Mon Jun 29, 2015 5:50 am Post subject: |
very hard to find. I need one. _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Posted: Mon Jun 29, 2015 7:48 am Post subject: |
vwbusman66 wrote: |
James |
Standard sliding buses, have 1 popout window on the door side. The first window.
And it opens from the rear, with the special latch, and special glass.
The sliding mechanism is different from bay window, the handle is difficult to get as well (if you want to key it for a 66), else a bay window handle can fit.
The jackpoint outrigger is different due to the sliding cutout.
The sliding door side, exterior side member is same as bay window.
The inner sliding rail is different from bay window.
The floor board, u can get the standard and modify the ends.
The rubber is not easy to get as well, but you can improvise on using a square profile rubber. You'll need to cut and join yourself in most cases.
Given a chance, and through my experience with one, if I have 2 buses infront of me in same (needing restoration) condition, I'd just take the one with hinged doors, the parts bill on a slider door may be enough for a lot of replacement metal pieces. |
Posted: Mon Jun 29, 2015 12:00 pm Post subject: |
orangebug60guy wrote: |
very hard to find. I need one. |
I also need this part, lol. The reason I need it is I decided to heat mine with a propane torch to free it up.........very stupid idea. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Posted: Thu Jul 02, 2015 2:22 am Post subject: |
I believe a member on this forum (vintage dreamz) has a spare windowed sliding door with parts still attached. Expensive though. |
iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2041 Location: M*ssholia
Posted: Thu Jul 02, 2015 7:18 am Post subject: |
mandraks wrote: |
might be easier to turn it into a regular bus |
might be easier to turn it into a bunch of pieces... Yikes that thing is rough. |
Posted: Mon Aug 31, 2015 3:40 am Post subject: |
Does anyone know if the bay window sliding door internal handle : 211843642A will fit the 64-66 exterior sliding door shaft?
I need a confirmation before ordering a handle, mine is wobbly and seemed to have been 'modified' from the winged door handle. |
Posted: Tue Sep 01, 2015 12:52 am Post subject: |
I have the early bay esceuteon and handle currently working in my 64 bus. Must file door to accept slightly larger esceuteon. Oh shit I thought you meant exterior handle. That handle should fit since Im using the exterior bay window door handle. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
