VolkDubz Samba Member
Posted: Sat Jun 27, 2015 8:53 pm Post subject: Transmission cut off for Engine test stand |
I was going to build a engine test stand this week, looked around on TheSamba and it didn't look that hard. Question is what is a stock transmission made of? I know the old motor blocks were magnesium but was wondering about the transmissions just in case I start cutting into it and sparks start flying....... and wont go out
also what is the best method for cutting? I have a cutoff wheel or a sawzall with metal blade, any other tool that will do the trick. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Sat Jun 27, 2015 9:02 pm Post subject: |
they are magnesium, and you have to try really hard to set one on fire. It's really, really not easy. Sawzall or cut off wheels will work.
The dust from cutting the case is a different matter, sweep it up, as that can and will catch fire easily. I had a surprise when some welding sparks hit some mag shavings
only lasted a few seconds but was bright and hot |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sun Jun 28, 2015 1:58 am Post subject: |
I used the bell-housing from a bus gearbox, it's bolt-on (bolt-off?). |
Posted: Sun Jun 28, 2015 2:02 am Post subject: |
When you're sawing the magnesium, it's all good until you brush up against steel, then the sparks fly, and it's like someone took your picture in 1920...with a big flash! won't be enough to light the housing, unless you're really unlucky. |
Posted: Sun Jun 28, 2015 5:58 am Post subject: |
esde wrote: |
Got it, thanks |
Dale M. Samba Member
Posted: Sun Jun 28, 2015 6:52 am Post subject: |
Sawzall and shop vac.... Keep cutting dust to minimum... IF it goes "poof" in your lap (clearancing bellhousing) its a real surprise...Ask me how I know....
IF you can find one a 002 bus bell housing it the best (091 requires specific starter)
Bell housing mounted on "build stand" to be used as a "run stand"...
At minimal needs...
mark tucker Samba Member
Posted: Sun Jun 28, 2015 9:12 am Post subject: |
I dont bother cutting the trans as that can cause leeks.I like to drive mine. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sun Jun 28, 2015 11:00 pm Post subject: |
I left the case whole, it makes it very stable
some day I will finish it
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Wed Jul 01, 2015 5:05 pm Post subject: |
You guys are making this too difficult, 5 minutes with a Sawzall will get a piece of bellhousing cut from the tranny case to mount a starter. Cut enough to get the left (right side) studs for a two bolt mount.
I clamp a VR to the starter with hose clamps and wire the gen so it works, that's a toggle for ign and a gen light. The oil light is separate.
I use an outboard motor fuel tank (2 gal?) for fuel supply,
You can run it on the ground, on a stand (?!) or on a cart.
I usually use a cart.
You don't want this thing to take up acreage when you store it, unless you have a 100,000sf building that's empty.
Good Luck! _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
Posted: Thu Jul 02, 2015 5:18 am Post subject: |
Dale M. wrote: |
At minimal needs...
Dale |
I really like this, good job.
I'm wondering about the bell housing height, are most really low so you can just slid the engine to it and bolt up? also what's the best method to bolt a saw'd trans half to a stand? |
Posted: Thu Jul 02, 2015 5:47 am Post subject: |
About only place you can bolt a sawzalled one is where R&P side covers are...
Bell housing is only maybe 5-10 pounds with starter a bit more.... bell housing mounted low because I use a atv jack to move motors around...
Also to me a engine mounted high (on typical yoke) is to susceptible to off balance and falling when running....
http://www.thesamba.com/vw/forum/viewtopic.php?p=6913870#6913870
Check "engine run stand", "engine test stand" thread(s) for more details...
http://www.thesamba.com/vw/forum/viewtopic.php?t=288599
tperazzo Samba Member
Joined: October 20, 2008 Posts: 90 Location: Huntington Beach, Ca
Posted: Wed Jul 22, 2015 11:18 pm Post subject: |
$109 and you're done from www.zalexindustries.com _________________ Tom Perazzo
1964 SC Coupe under restoration |
Dauz Samba Member
Posted: Thu Jul 23, 2015 11:57 am Post subject: |
Unbolt the bellhousing from a T2 trans.. no cutting. |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Thu Jul 23, 2015 6:44 pm Post subject: |
The Type 2 bell housings are no longer the cheap route. Not sure what they're going for in your neck of the woods, but I got $75 out of the last one I sold recently. You should be able to find a Type 1 case/starter chunk for less than $20. |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Thu Jul 23, 2015 6:51 pm Post subject: |
earthquake wrote: |
Casey |
I don't know - looks like a leaverite to me - and ready to run. Put some rockers on the bottom and you can entertain the grandkids later on... _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Thu Jul 23, 2015 9:20 pm Post subject: |
[email protected] wrote: |
...You should be able to find a Type 1 case/starter chunk for less than $20. |
The last one I bought cost me $5. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Posted: Fri Jul 24, 2015 7:32 am Post subject: |
My type 2 bell housing with SR17 self supported starter was $10...
Posted: Fri Jul 24, 2015 10:22 am Post subject: |
Dale M. wrote: |
Dale |
I'll buy all the ones you can find for that price! You can quintuple your money by selling it to one of the few with wanted adds in the classifieds offering $50-$65. |
RealThing74 Samba Member
Posted: Sat Oct 03, 2015 7:33 pm Post subject: |
I wish I lived where I could find a housing to make a engine test stand as cheap as has been posted here. Best I got was a complete transmission for $150. I'm in SW Colorado. _________________ Mike
81 Vanagon Westy
74 Thing Currently under a pan off restoration
73 Standard Beetle that we tow behind our Motorhome & use for sightseeing.
Click to view image |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
