Franklinstower Samba Member
Posted: Sun Jun 28, 2015 3:47 pm Post subject: Need help in Redding, CA: Tranny seal blew |
we Need A Seal And Floor Jack Etc. _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
zastrow_qr Samba Member
Joined: May 19, 2005 Posts: 48 Location: Northeast Oregon
Posted: Sun Jun 28, 2015 4:25 pm Post subject: |
Subagon and Burley Motorsports are in Redding |
Posted: Sun Jun 28, 2015 5:09 pm Post subject: |
Pretty sure I read recently that Burley relocated to Santa Barbara. Their # is also area code 805 now. _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
Posted: Sun Jun 28, 2015 5:29 pm Post subject: |
we left a message with Jim at subagon, the problem is getting a new seal in a reasonable amount of time. _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
iliketowalk Samba Member
Joined: April 29, 2011 Posts: 614 Location: Northern CA
Posted: Sun Jun 28, 2015 6:26 pm Post subject: |
Left you a VM - which tranny seal do you need? Cheers, James _________________ 1986 Weekender "Birch" |
Posted: Sun Jun 28, 2015 6:32 pm Post subject: |
It would certainly help to know which seal you need and even which transmission you have, manual, automatic? No one can point you in the right direction if you don't tell them where you need to go. Are you even sure it is a tranny seal? What are your symptoms? |
Posted: Sun Jun 28, 2015 9:36 pm Post subject: |
Depending on which seal you need, I may have what you need just a 3 hr drive away (aka... "Overnight Express"). Of course VC or GW can easily overnight anything you need as well. Good luck and get the hell out of there ASAP!!! Have you seen the weather forecast for this week . _________________ 1990 Multivan - "Ohana"
Posted: Sun Jun 28, 2015 10:13 pm Post subject: |
ThankYouJerry wrote: |
Have you seen the weather forecast for this week . |
Its only supposed to be 35°F above normal so whats the problem? |
Posted: Mon Jun 29, 2015 8:39 am Post subject: |
115F builds character.
Posted: Tue Jun 30, 2015 11:28 am Post subject: |
Thanks for the help and replies. James, Burley, and especially Jim at Subagon. Jim gave us access to an unused bay at his shop, Jim gave us a seal, jack and floor stands. We pulled the auto trans out of my friends westy, got the new seal in but noticed the bushing inside the torque converter was completely gone. Jim had a spare torque converter we got that all installed and buttoned back up. But the damage was already done and the trans wouldn't hold the ATF. The Input shaft must have gotten damaged and the seal couldn't keep the fluid from leaking out. The pan and filter looked like sluice box filled with gold flakes!
Took a rental car home. All is well.
Thanks again.
Paul _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
Posted: Tue Jun 30, 2015 1:11 pm Post subject: |
Just rent a U-haul and a car trailer and tow her home. Way less bother than having to deal with a car that is broken down hundreds of miles away. |
