Generator replace help!!!
Page: 1, 2, 3  Next
jcoo9614
jcoo9614 is offline
PostPosted: Mon Jun 29, 2015 8:09 am    Post subject: Generator replace help!!! Reply with quote
The generator in my 1972 VW Super went bad some time last week. I went ahead and bought a new one since everything I read online made the job seem fairly easy. At the bottom of the panel that attaches to the fan, there are two screws that are blocked by dual port intake manifold. I tried to remove this but there are two nuts that I cannot reach with any socket or wrench that I have tried. Do I have to take this to a shop? I'm so frustrated with this. Please let me know
APPLEGREENVW
APPLEGREENVW is offline
PostPosted: Mon Jun 29, 2015 9:51 am    Post subject: Reply with quote
Remove the manifold.
Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan
Harleyelf
Harleyelf is offline
PostPosted: Mon Jun 29, 2015 10:10 am    Post subject: Reply with quote
Loosen the right manifold, remove the left one, loosen the clamps on the rubber boots and slide the boots onto the manifold tube, and remove the nut behind the distributor that holds the manifold tube to the case. Remove the throttle cable from the carburetor throttle lever and unbolt the pre-heater screws from the exhaust.
Now the manifold tube should slide to the left and lift enough to access those pesky fan bolts. No need to disconnect the fuel lines.
jcoo9614
jcoo9614 is offline
PostPosted: Mon Jun 29, 2015 10:15 am    Post subject: Reply with quote
I can't access the nuts to pull the manifold off either. I can't get a wrench to fit in
jcoo9614
jcoo9614 is offline
PostPosted: Mon Jun 29, 2015 10:44 am    Post subject: Reply with quote
I can only get a very small 1/2" wrench in and I can only push it counter-clockwise. Is this the right direction? if it is then I'm just not pushing hard enough
jcoo9614
jcoo9614 is offline
PostPosted: Mon Jun 29, 2015 11:39 am    Post subject: Reply with quote
These are some pictures of the nut. The nut is directly behind the red plug. As you can see it is almost impossible to reach. I can't get it to turn at all[/img]
Cusser
Cusser is offline
PostPosted: Mon Jun 29, 2015 12:18 pm    Post subject: Re: Generator replace help!!! Reply with quote
Here's what I've always done (1970 and 1971 VWs with generators). I disconnect battery negative terminal. I mark the position remove the engine lid. I remove the accelerator cable and pull through the fan shroud and the wires - you mark the wires, you don't have my experience, or you wouldn't be posting this topic). I disconnect the strap holding the generator to the mount/stand. I remove the carb from the intake manifold. I lift the entire fan shroud up and out of the VW, and work on it out of the car. So I leave the intake manifold in place.
By the way, a "1/2 inch wrech" has no place near a VW wnfine, those nuts take a 13mm wrench. Or you could use JIS Japanese nuts which take 12mm wrench.
jcoo9614
jcoo9614 is offline
PostPosted: Mon Jun 29, 2015 1:26 pm    Post subject: Reply with quote
how do I take out the fan shroud?
jcoo9614
jcoo9614 is offline
PostPosted: Mon Jun 29, 2015 1:36 pm    Post subject: Re: Generator replace help!!! Reply with quote
How do I take out the fan shroud? do you have a video for this?
GArBa
GArBa is offline
PostPosted: Mon Jun 29, 2015 2:23 pm    Post subject: Reply with quote
your pics aren't surely the best, but it looks to me that red plug isn't a plug at all. it's the bakelite/plastic insulator at the end of the HT lead that somehow has stayed attached to your plug (it should come off together with the HT lead). once removed that, the actual spark plug's tip should be barely visible through the cooling tin, ensuring a much better access.
that said, to work around a beetle engine compartment with a socket wrench, you will need, aside from the correct metric bits, a lot of extensions and universal joints.
Or, you can use small low profile metric wrenches, dentists'mirrors and huge loads of patience.
cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v
iowegian Premium Member
Samba Curmudgeon
iowegian is online now
PostPosted: Mon Jun 29, 2015 2:29 pm    Post subject: Reply with quote
Remove the engine from the car.
Kiptere
Kiptere is offline
PostPosted: Mon Jun 29, 2015 2:30 pm    Post subject: Reply with quote
Just pull the fan shroud and generator off all in one piece. Disconnect the fan shroud. Disconnect the generator strap. Leave the generator plate connected to the fan shroud. Remove the rear deck lid. Remove the deck lid hinges. Pull the whole fan shroud and generator up and out (all in one piece). I replaced my generator a couple of months ago and this is how I did it.
62 Bug
70 Bug
68 Bug
70 Bug Vert
jcoo9614
jcoo9614 is offline
PostPosted: Mon Jun 29, 2015 4:36 pm    Post subject: Reply with quote
Do I have to remove the engine to take off the fan shroud?
P.S. I really appreciate all the help
APPLEGREENVW
PostPosted: Mon Jun 29, 2015 4:44 pm    Post subject: Reply with quote
Remove the spark plug to get access the nut.
02/76 Beetle sedan
Samba Curmudgeon
PostPosted: Mon Jun 29, 2015 5:36 pm    Post subject: Reply with quote
You don't have to, but quite honestly with all of the trouble you seem to be having, it might possibly be easier in the long run. (or not).
Q-Dog
Q-Dog is offline
PostPosted: Mon Jun 29, 2015 6:56 pm    Post subject: Reply with quote
I have changed a few generators and only once did I do it with the engine in the car. NEVER again! So much faster and easier to pull the engine.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
Zylinderkopf
Zylinderkopf is offline
PostPosted: Mon Jun 29, 2015 9:25 pm    Post subject: Reply with quote
Here's a good video on how to replace the generator with the engine in.
http://youtu.be/4ewXkdPgsa4
1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to."
Samba Curmudgeon
PostPosted: Tue Jun 30, 2015 4:53 am    Post subject: Reply with quote
I love how the expert mechanic uses his ratchet handle as a hammer at 4:46. Laughing
jcoo9614
jcoo9614 is offline
PostPosted: Tue Jun 30, 2015 6:55 am    Post subject: Reply with quote
I finally got the manifold off but in the process I dropped a 13mm socket into a pipe that a hose was attached to.... I'm wondering if I have to take that apart to remove it or can it be left in there (Stupid question I know but humor me please)
jcoo9614
jcoo9614 is offline
PostPosted: Tue Jun 30, 2015 7:30 am    Post subject: Reply with quote
The socket fell into this
it fell into the little extension on top
Page: 1, 2, 3  Next
