Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Fri Jul 03, 2015 1:08 pm Post subject: |
Did you put on new wires? Judging by your pictures you still had the stock style 2 piece wires and you ripped the end off one. |
jcoo9614 Samba Member
Posted: Fri Jul 03, 2015 2:08 pm Post subject: |
Yeah I put on new wires not new spark plugs. Is it possible to mess up the old spark plugs? Maybe I was too forceful with the new wires? |
Posted: Fri Jul 03, 2015 4:48 pm Post subject: |
What kind of socket will I need to remove the spark plugs in my 72? Can someone send me an amazon.com link? |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Fri Jul 03, 2015 5:10 pm Post subject: |
Have you done what Cusser said?
Cusser wrote: |
Check and re-check the order of the spark plug wires. And wires to the coil. |
There should be no good reason to replace the spark plugs at this point. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Fri Jul 03, 2015 6:29 pm Post subject: |
jcoo9614 wrote: |
I can only get a very small 1/2" wrench in and I can only push it counter-clockwise. Is this the right direction? if it is then I'm just not pushing hard enough |
When I saw this post, I just knew there would be trouble !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri Jul 03, 2015 9:10 pm Post subject: |
Yes I checked all the wires. Everything is hooked up right. The engine turns over just won't start.
This is the first time I've had to work on a car so... I'm new. Sorry |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Fri Jul 03, 2015 11:43 pm Post subject: |
jcoo9614 wrote: |
very unlikely. you should feel the little spring in the lead connector scrape the threads on the plug tip when you put them on. What type of leads did you use? some aftermarket leads require you to put back the screw on connector on the plug.
You said you had to wrestle the gen out, so check your carb and distributor to see if anything has been knocked off during the process. while you are at it also check all the correct wires are still connected to the coil.
Finally, you say that your gen went bad. how did you determine that? you may have to check your voltage regulator, too. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
Posted: Sat Jul 04, 2015 6:40 am Post subject: |
GArBa wrote: |
jcoo9614 wrote: |
Finally, you say that your gen went bad. how did you determine that? you may have to check your voltage regulator, too. |
Maybe there was nothing with it all along and the car was just out of gas? |
GArBa Samba Member
Posted: Sat Jul 04, 2015 1:52 pm Post subject: |
as suggested:
GArBa wrote: |
while you are at it also check all the correct wires are still connected to the coil. |
it may be as simple as a disconnected wire. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
Posted: Sat Jul 04, 2015 5:21 pm Post subject: |
Exactly what wires need to be plugged into the distributor and the ignition coil. I have compared what I did to a picture from before and it looks the same... |
GArBa Samba Member
Posted: Sun Jul 05, 2015 12:54 am Post subject: |
download the wiring diagram for your '72 super from the following page, the connections at the coil are quite simple to follow.
http://www.thesamba.com/vw/archives/info/wiringt1.php _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
Posted: Mon Jul 06, 2015 11:26 am Post subject: |
Okay, I checked the wiring from the diagram and I had it wired wrong. Now it starts for half a second and then pops and turns off. |
Posted: Mon Jul 06, 2015 2:05 pm Post subject: |
got it to start. Had to hold the pedal down and turn the key. However, I can't let off the pedal or else it turns off and it sounds like a lawn mower... what!?! |
Posted: Mon Jul 06, 2015 2:17 pm Post subject: |
jcoo9614 wrote: |
Can you use it to mow the grass? |
talljordan Samba Member
Joined: January 10, 2012 Posts: 964 Location: San Francisco, CA
Posted: Mon Jul 06, 2015 4:54 pm Post subject: |
Didnt you loosen an intake manifold earlier? Maybe you should tighten it again. Vacuum leaks will cause the symptoms you are describing. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
vamram Samba Member
Posted: Mon Jul 06, 2015 6:27 pm Post subject: |
jcoo9614 wrote: |
Timing. Are you using points? Find a procedure to statically time it, that should get it to at least start and run, then you can use a timing light to set the advance correctly.
Also - since you were messing w/your intake manifold, are you sure you didn't end up w/a major vacuum leak?
[NOTE: I've been "offline" for about a month so missed the beginning of this thread. For the record, I've changed the alternator on my '72 Super by using an 18" breaker bar on the 36 mm nut, loosened the 4 bolts that hold the alternator fan shroud tin to the shroud, removed the carb, and the alternator stand, removed the alternator, installed the new one, voila, no engine drop, manifold or shroud removal. It was actually quite easy to do it this way.] _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
TheAmazingDave Samba Member
Joined: April 11, 2013 Posts: 788 Location: San Jose, CA
Posted: Mon Jul 06, 2015 6:44 pm Post subject: |
jcoo9614 wrote: |
Does your carb have an idle circuit cut-off solenoid (sticking out of the left side of the carb, and has a wire connection on it), and is it connected to power?
If it does, and it's disconnected, that's pretty much exactly how it will run. _________________ Just call me Big D. (formerly xBigDx408x)
TheAmazingDave.net
Deutschland Dubs 2015 at Presidio Trust |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Mon Jul 06, 2015 8:41 pm Post subject: |
I'd double check the firing order of the plug wires too. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
