sean14538 Samba Member
Joined: June 03, 2014 Posts: 161 Location: West Jefferson, OH
Posted: Wed Jul 01, 2015 6:30 pm Post subject: |
June 28th 2015, replaced Master cylinder and bled all the brake lines. also engine decided not to start, seemed like it was not getting fuel, so we replaced fuel filter, and fuel pump roughly $35, turned out when Heather tightened up the throttle cable she accidentally turned the choke adjuster screw all out of whack. _________________ '71 Westy - 1600cc
Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=631317
How to post photos:
Pinetops Samba Member
Posted: Mon Oct 05, 2015 8:20 pm Post subject: |
I like your bus. It's presentable, yet not so perfect that you can't really enjoy it. I'd like to have one just like it. The sound deadening is going to be nice but what is the purpose of the foam in the holes? _________________ "A rolling bus gathers no rust." |
Posted: Wed Oct 21, 2015 11:57 pm Post subject: |
Well, I started getting the stained panels back in the bus. I think that they turned out excellent! really happy with how it is looking. with the sound deadening, insulation, and the panel back on the rear hatch door, it sounds so satisfying hearing it close
Build Thread:
How to post photos:
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Thu Oct 22, 2015 9:33 am Post subject: |
Bus looks great! That sound deadening will make a huge difference. I probably only have done half of what you did and it's 50% quieter. Now get some good speakers in there
What kind of foam did you use though? Unless it's closed cell that'll trap moisture inside all those cavities... Even if it is closed cell, spray foam on metal makes me nervous. _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
Posted: Thu Oct 22, 2015 9:51 am Post subject: |
The interior is looking good. _________________ "A rolling bus gathers no rust." |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Sat Nov 07, 2015 10:24 pm Post subject: |
I saw your post below in the "What have you done recently for your bay?" thread.
sean14538 wrote: |
put in the flooring on my camper think it will look pretty nice!
Looks great. Before you button it all up, I would be a little concerned about that spillguard product you have installed (visible in the rear seat and wheel well area in the above picture) holding moisture.
The product was designed to place under area rugs to protect the rug and the underlying hardwood floor. It is designed to retain moisture which is exactly what you do not want in this application. Easier to fix it now than later. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Posted: Sat Nov 07, 2015 10:28 pm Post subject: |
sean14538 wrote: |
I filled all the hollow areas with foam, didn't get as much done as I had hoped this weekend.
Make sure you leave any of the original lower weep holes open for moisture to drain out. Foam is not your friend in those areas. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
twowings Samba Member
Joined: September 04, 2010 Posts: 23 Location: Tulsa, OK
Posted: Sun Nov 08, 2015 3:22 pm Post subject: |
You have done an amazing amount of hard work! My compliments! |
vwmike Samba Member
Joined: November 19, 2001 Posts: 156 Location: Fraser Valley, BC, Canada
Posted: Mon Nov 09, 2015 9:10 am Post subject: |
Can't wait to hear how much quieter it will be ! |
Posted: Sat Nov 14, 2015 7:42 pm Post subject: Re: My '71 Westy |
Well, I didn't quite get the other projects finished, but decided to start another I wanted to take the dash apart to clean it really good and give it a couple coats of vinyl paint. a lot of the bolts along the windshield base were rusted in place and had to drill them out, but otherwise it went fairly smooth.
[/img] _________________ '71 Westy - 1600cc
Build Thread:
How to post photos:
