ronfis Samba Member
Posted: Tue Jun 30, 2015 12:34 pm Post subject: Rear brakes don't have enough oomph |
I completely refurbished the brake system in my '57 Oval. The front brakes work fine, but the rear wheel cylinders only work when the brake-pad springs are disconnected. The system has been bled fully. Any thoughts? |
splitjunkie Samba Member
Posted: Tue Jun 30, 2015 12:45 pm Post subject: |
Did they work before you did your work?
Did you replace all of the hard lines and the rubber lines? _________________ Chris
ronfis Samba Member
Posted: Tue Jun 30, 2015 1:00 pm Post subject: |
Splitjunkie: The car was in lousy shape when I got it -- the old wheel cylinders were rusted in place. I replaced everything. When I pull the springs off the brake pads and press the brakes, the cylinders move so far that the rubber seals separate from the cylinder housing. With the springs on, no movement. Thanks. |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Tue Jun 30, 2015 3:17 pm Post subject: |
An early master cylinder is a single circuit that provides equal pressure to all four corners.
A plugged line (or possibly the tee fitting) would cause a problem, but then you would not be able to bleed the rear wheel cylinders properly.
Are all the brakes stock (type) drum brakes? _________________ Jesucristo es mi Seņor y Salvador! |
slalombuggy Samba Member
Posted: Tue Jun 30, 2015 5:03 pm Post subject: |
A sealed hydraulic system will have equal pressure in all directions no matter how many points there are in it. Did you kink the front to back line or has it been pinched somewhere. A restriction in the rear lines is the only reason you will not have the same pressure front and rear. Since it affects both rear cylinders the same I would examine the front to back line.
brad |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Jun 30, 2015 7:16 pm Post subject: |
... what did you replace? You might have to replace hard lines and flex lines to the back... sounds like a blockage, to me. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Wed Jul 01, 2015 12:52 am Post subject: |
You stated that you've replaced everything; could you have made a bent in one of the hard brake lines (most likely the longest line which runs along the tunnel from front to back) too sharp, which would now obstruct the full flow of brake oil to the wheel brake cylinders in the rear? _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Wed Jul 01, 2015 4:59 am Post subject: |
You either have failed seals inside the master cylinder, or you are mistaken when stating that the system is fully bled, or both.
I ran into a problem doing some brake bleeding last year on my Vanagon and the solution for me was to push a little bit of brake fluid from the wheel cylinder back towards the master cylinder and that was all it took to dislodge a pocket of air inside my master cylinder. You can even use air to push a small amount of fluid back up the line, then bleed that air out again. |
ronfis Samba Member
Posted: Wed Jul 01, 2015 8:31 am Post subject: |
Guys: Thanks to all. Grteat ideas, and I appreciate the help. |
