vanis13 Samba Member
Joined: August 15, 2010 Posts: 3099 Location: ABQ NM USA.... Except when not
Posted: Tue Jun 30, 2015 12:36 pm Post subject: What are these things for on the B & C pillars? |
What are these holes and screws for?
A - plastic white knob - ?
B 1,2,3 - plastic small black knobs - ? – side window curtain mounts?
C 1,2 - metal snap - ? - F windows curtail snap?
D – rear window plastic valance (curtain rod cover) no longer there
E – hole approx. 1/8” - ?
F 1,2 - threaded plugs white - ?
G – hole approx. 1/4 ” - ?
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Tue Jun 30, 2015 1:00 pm Post subject: |
A -- For hanging a clothes rod (used to be a popular after-market accessory for hanging your shirts on hangers). There would have been a corresponding knob on the other side of the vehicle.
B -- Correct - some years of Vanagons (my 84 for example) had those buttons/pegs/knobs for the elasticized curtain for the slider. The curtain has a white plastic ring on each corner to pop over those knobs. Not sure what became of B4, i.e. you should have one more at the lower rear corner.
C -- Yes, snaps for the front curtain. Should also be a simplar pair on the driver's B pillar.
D -- Yep, as I recall that is how my rather fragile plastic valence is attached.
E, F & G -- No idea. I have often wondered what purpose those white plastic plugs might serve. Possibly they and those extra holes had some use on tin-tops. |
syncroluvr Samba Member
Joined: October 11, 2010 Posts: 200 Location: Trois Rivieres,QC
Posted: Tue Jun 30, 2015 1:01 pm Post subject: |
Hi! I use C1 and C2 for my front and side window curtains. After use I store them in the back. _________________ 1990 Syncro Westy with stump pulling 2576cc Subaru
Y2K V6 Passat
Calcandi Leviter |
jimf909 Samba Member
Posted: Tue Jun 30, 2015 1:02 pm Post subject: |
Ooh, looks like fun. I'll try w few:
A - that's for hanging your dry cleaning
B - that looks suspisciously like anchors for the mystery curtain that was mentioned in a thread the other day
C - that's easy, for the front window curtain
D- F hmmm...
P.s. I think you intended to say B & C pillars? _________________ - Jim
Abscate wrote: |
Vanagon Nut Samba Member
Posted: Tue Jun 30, 2015 1:04 pm Post subject: |
a handy for stringing a bungee and material if no front [edit] curtain. Don't know of OEM application(s).
Coat hook? I've used it for that.
b curtain mounts for old style curtain.
c front curtain snaps
F1/2 are seat belt bolt type holes. Not sure of OEM application(s) but I've used them for securing things. GW or van-cafe sells eyelet bolts that will thread right in.
1988 West DIY 50º ABA
VE7TBN |
