necro1250 Samba Member
Joined: June 27, 2010 Posts: 47 Location: Pennsylvania
Posted: Tue Jun 30, 2015 12:40 pm Post subject: Gas heater? |
Ok so I have a 1980 standard beetle and I am in need of a gas heater for winter. I was wondering if anyone know which heaters fit my car because so far I have heard different things from different people? Also if anyone know where to get a complete gas heater kit I would greatly appreciate it. _________________ Thanks,
Jim
1980 Std Mexi Beetle |
Bruce Samba Member
Posted: Wed Jul 01, 2015 2:04 am Post subject: |
Standard Beetles up to 70 (or 71?) came with a B-2 Eberspacher gas heater. After 72, standard Beetles came with a BN-2.
I prefer the simplicity of a B2, so that's what I installed in my 75 Standard Beetle. It's not a simple installation like it would be for an earlier car due to the lever that controls the heater. This lever is to the left of the steering column and on post 72 cars, the fuse panel is where the lever needs to be. I was able to alter the shape of the lever to work around the fuse panel. _________________
Posted: Wed Jul 01, 2015 4:05 am Post subject: |
Awesome thanks for the info. _________________ Thanks,
Jim
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Wed Jul 01, 2015 4:19 am Post subject: |
A BN4 from a Thing could probably be made to fit as well. It is a bit bigger than the BN2, but may be easier to find. |
CarlIseminger Samba Member
Joined: May 12, 2008 Posts: 833 Location: Grand Forks, ND
Posted: Wed Jul 01, 2015 10:32 am Post subject: |
There is also another manufacturer of gas heaters approved by VW for standard beetles. Stewart Warner South Wind. They made two different types. One that mounted on the passenger side of the truck and one that mounted on the driver's side of the trunk. Very easy to install and maintain. There are several in the want ads.
But beware of any used heater you buy, it could have rust you can't see in the combustion chamber that would put CO into the cabin.
I have a South Wind installed on the driver's side of my car. I keep it clean and good gas hoses. Works wonderfully in the winter. Usually have to turn it off it gets so hot in there _________________ 1969 VW Beetle Convertible |
Bruce Samba Member
Posted: Wed Jul 01, 2015 4:01 pm Post subject: |
Bashr52 wrote: |
IMO this is bad advice.
A Thing BN4 doesn't "fit" a Beetle because there aren't any ducts available. Sure you could waste your time trying to make it work, but why would you when other heaters are properly engineered to fit perfectly?
Easier to find? Doubtful. A few thousand Things were made, millions of Beetles. Ask any Thing owner. Nothing specific for their cars are easier to find than the equivalent Beetle part. _________________
Posted: Thu Jul 02, 2015 9:45 am Post subject: |
Thanks for all the help. I have decided to go with a Stewart Warner heater _________________ Thanks,
Jim
Posted: Thu Jul 02, 2015 10:40 am Post subject: |
There are a couple of user/install manuals in the Technical section. While they might not be for the particular heater you buy, the South Winds all operate the same way, just that some of the parts are in different locations depending on the install setup. _________________ 1969 VW Beetle Convertible |
Posted: Thu Jul 02, 2015 11:49 am Post subject: |
Ok awesome thank you very much I will have to take a look.
CarlIseminger wrote: |
There are a couple of user/install manuals in the Technical section. While they might not be for the particular heater you buy, the South Winds all operate the same way, just that some of the parts are in different locations depending on the install setup. |
Jim
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Thu Jul 02, 2015 12:02 pm Post subject: |
Out of curiosity,
How long does a bug last in a salt slurry?
Most new cars have some protections.
My brake rotors unprotected become a blooming onion of rust right away.
Have I not seen bug victims of salt.
It's a sad sorry situation to see.
stay warm.
PS
I spent last winter homeless living in and out of the car last winter in Vermont.
20-30 below add howling windchill.
It wouldn't start let alone run the heater, or warm up enough to. |
Posted: Thu Jul 02, 2015 12:05 pm Post subject: |
My bug is my daily driver up here in North Dakota. We don't use very much salt. But after 6 years, it is starting to show rust around the headlight buckets and a bit at the bottom of the fenders.
I wash the car regularly in the winter at the car wash. Aiming the hose under the car.
It also parks in a heated garage, so all the snow can melt off. _________________ 1969 VW Beetle Convertible |
Posted: Mon Jul 06, 2015 8:55 am Post subject: |
DeathTrap wrote: |
Out of curiosity,
stay warm.
PS
I drove mine in Germany for over 5yrs year round. I washed it at least twice a week. It had some rust when I bought it and I have been slowly fixing it up. Now im in Pennsylvania and they salt the roads alot here to. I have began to look at rust repair as normal maintenance. _________________ Thanks,
Jim
mukluk Samba Member
Posted: Mon Jul 06, 2015 9:40 am Post subject: |
necro1250 wrote: |
I have began to look at rust repair as normal maintenance. |
You really do need to when you live in the rust belt. Back when I used to live in Ohio, I had a twice-yearly routine where I would put the car up on ramps or jack stands and go over the entire undercarriage, treating any rust with a rust converter then touching up the paint to keep things protected. This was done when things would warm up in the Spring time, then again in the Fall before the cold and salt trucks started to make their rounds. _________________ 1960 Ragtop w/Semaphores "Inga" |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Mon Jul 06, 2015 9:44 am Post subject: |
Around here they rotted in the salt just like any other car from the 60's or 70's. After 10 years they often had holes in the floor pan, rotted door sills, even frame damage. _________________ 1958 Karmann Ghia owner |
Otislee Samba Member
Joined: December 15, 2011 Posts: 26 Location: Danville ky
Posted: Sun May 01, 2016 10:33 am Post subject: Re: Gas heater? |
Anyone have any info for a model b12 Stewart Warner south wind?? _________________ 72 w/wonderbug frontend
74 baja coal black
70 rat project
78 van
69 T3 squareback euro automatic
67 probably rat it's so ruff
66 bug
63 ragtop
62 bug
59 ragtop
Miss the 89fox an 95cabrio |
busdaddy Samba Member
