ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Jun 30, 2015 7:00 pm Post subject: '56 Ragtop Question |
... see number 44. when the canvas top is stretched over it, what holds the canvas on to this piece?
When the roof is slid back, the canvas can separate off this metal... I know something must hold the canvas on. Like a clip, screw or pop rivet AND whichever little part... how is it applied?
Thanks so much
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Jun 30, 2015 7:15 pm Post subject: |
IIRC the original was installed using a split rivet and that was what the replacement covers use to come with. I used pop rivets to hold mine on (1960) and some people just use a glue like contact cement _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Tue Jun 30, 2015 8:00 pm Post subject: |
60ragtop wrote: |
IIRC the original was installed using a split rivet and that was what the replacement covers use to come with. I used pop rivets to hold mine on (1960) and some people just use a glue like contact cement |
Do you apply the rivet from the top, through the canvas cover or from the bottom, through the canvas? I guess glue and pop rivets would do. _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Posted: Tue Jun 30, 2015 8:12 pm Post subject: |
from the inside where the material folds over. I have a canvas top -been on there since 1997
once riveted, I used tape along the whole length along the topside to further cover the rivets so they don't show thru. I have to think real hard as it's been so long I did it. I don't know how the rivets would work on a vinyl cover tho? _________________ Rick
tasb wrote: |
sb001 wrote: |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Wed Jul 01, 2015 11:43 pm Post subject: |
60ragtop wrote: |
I don't know how the rivets would work on a vinyl cover tho? |
It works the same way . . . the rivets had a special head design to sit flush in the countersunk holes.
The rivets on mine had push-nuts just like these . . . http://www.mcmaster.com/#90528a127/=xvfsis
You will have better access to the ends of the rivets if you are able to first remove those two special screws (#49 in the illustration) that attach the bow to the rest of the mechanism.
There is also a sponge-rubber strip that is adhered to the bottom of the bow before the cover is attached to the bow. _________________ Jesucristo es mi Seņor y Salvador! |
vegasSTEVE Samba Member
Joined: February 12, 2004 Posts: 35 Location: Henderson, Nevada
Posted: Sun Jul 05, 2015 6:54 pm Post subject: |
57BLITZ wrote: |
60ragtop wrote: |
There is also a sponge-rubber strip that is adhered to the bottom of the bow before the cover is attached to the bow. |
I did exactly what 57BLITZ did.... and it worked very well..... _________________ 56 Oval Sunroof
59 Ghia Coupe
68 Single Cab
Las Vegas Volkswagen Club-1997 (Founding Member) An Officially Licensed VWoA Club |
