Anyone using one of these adapters for gauges?
david2676
david2676 is offline
PostPosted: Thu Jul 02, 2015 8:58 am    Post subject: Anyone using one of these adapters for gauges? Reply with quote
http://www.glowshiftdirect.com/Wideband-AirFuel-Gauges.aspx?sitelink=LeftNav
this thing sandwiches between he oil filter and block to give two ports for pressure and temp. The only down side I see is it gives and additional seem to fail.
What is better to watch oil temp or coolant temp ?
anyone running a fuel Air ration gauge ? Like this
http://www.glowshiftdirect.com/White-MaxTow-Wideband-Air-Fuel-Ratio-Gauge.aspx?sitelink=LeftNav
would it offer any warning or information as to what is failing ?
64 bug
91 Vanagon/ Subaru swap Westfalia
geodude
geodude is offline
PostPosted: Thu Jul 02, 2015 9:49 am    Post subject: Reply with quote
I've been using one of the sandwich adapters for awhile. It works. You just have to be careful to seal it to the block adequately (enough torque and clean surfaces). I have a VDO pressure gauge and a temp sensor, though I haven't gotten around to wiring the temp sensor yet. Of the two, pressure is likely the more important.
1988 GL Camper
1991 Multivan — the basket case
MarkWard
MarkWard is offline
PostPosted: Thu Jul 02, 2015 11:55 am    Post subject: Reply with quote
Given a choice, I'd prefer to know the coolant temperature. It reacts fairly quickly and since cooling system is external to the engine, more places for failure that if not caught quickly can lead to catastrophic failures.
Oil temp is slower to respond not much you can do about high oil temp other than backing your foot out of it. If you were adding say an external oil cooler it would be nice to measure before and after temps.
geodude
geodude is offline
PostPosted: Thu Jul 02, 2015 1:19 pm    Post subject: Reply with quote
^^ Misread the question. I agree with coolant temp is more important than oil temp. I'd monitor oil pressure and coolant temp before oil temp.
1988 GL Camper
david2676
PostPosted: Thu Jul 02, 2015 2:35 pm    Post subject: coolant temp Reply with quote
Then have a cleaver little item that you basically splice into one of the hoses so you have a port for the sensor. really easy stuff. i just need to figure out where I would mount the gauges.
64 bug
eeebee
eeebee is offline
PostPosted: Thu Jul 02, 2015 5:43 pm    Post subject: Reply with quote
Oil temperature (Oil pressure is best), you already have a water temperature gage and if it doesn't work then you should fix that first.
Eric
1987 Vanagon Wolfsburg Special Edition
GoWesty 2.3
Democracy is the recurrent suspicion that more than half of the people are right more than half of the time.
Timwhy
Timwhy is offline
PostPosted: Thu Jul 02, 2015 6:34 pm    Post subject: Reply with quote
Installed mine and gauges last weekend, very happy with the results!
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
scottychop
scottychop is offline
PostPosted: Fri Jul 03, 2015 9:08 am    Post subject: Reply with quote
Plugs right in and has multiple ports for use:
http://www.42draftdesigns.com/VW-Oil-Pressure-Relocation-Kit_p_314.html
rmcd
rmcd is offline
PostPosted: Fri Jul 03, 2015 9:45 am    Post subject: Reply with quote
I have used a bunch of 42 design stuff on my Audi. They do top notch work.
VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight=
HoustonPhotog
HoustonPhotog is offline
PostPosted: Fri Jul 03, 2015 4:18 pm    Post subject: Reply with quote
write up here
http://texasvanagons.com/oil-pressure-temperature-gauge-pod/
Abel Longoria
VanAlert App for Vanagons/Buses | Texas Vanagons | My Vanagon Build Thread | Follow Me On Instagram | Vanagon-centric Stickers Available Now
