wesharden Samba Member
Joined: August 18, 2013 Posts: 16 Location: Lake Havasu City
Posted: Thu Jul 02, 2015 12:16 pm Post subject: Swing axle rear seal slinger question |
My left rear axle seal was leaking. When I disassembled the #7 washer was missing. I reassembled with the washer provided in the new seal kit. Now the oil deflector #13 is tight against the cover #14. The deflector was loose before I disassembled.
Any ideas what I did wrong, am disassembling for inspection now.
Thanks in advance
Wes |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Thu Jul 02, 2015 7:58 pm Post subject: |
Dropped a fulcrum in the diff, the axle is now too far outward. Remove trans and axle assembly and re-assemble correctly _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Thu Jul 02, 2015 9:36 pm Post subject: Dropped fulcrum |
Is that a common occurrence? I did not let the axle move out while the cover was off, could it have been that way before I disassembled? I really dodn't have time to r&r the trans. Have run next weekend.
Thanks Wes |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Fri Jul 03, 2015 6:00 pm Post subject: |
Maybe check the outside spacer that rides in the seal. That spacer has a relief/bevel machined on one side to go over the small o-ring. Maybe this got flipped, and is not letting the spacer to butt up against the bearing properly, and wedging the splash washer into the cap. |
