theramny Samba Member
Joined: October 17, 2014 Posts: 77 Location: BUFFALO NY
Posted: Thu Jul 02, 2015 4:17 pm Post subject: info on this engine set up and builder |
im looking to by a 1835 off a guy and it was built by evil ed of cape cod as im not to knolegable on this set up would it be to much for a 71 vw bus the price is right
Mag 44 big valve machine honed heads with HD springs.
Machined heads and case spigots.
Dual oil relief German low mileage case.
Forged 92mm barrels and pistons.
Teflon wrist pin buttons, cc'd heads, deck height double-checked.
Mahle rings.
New bearings/seals/shims throughout.
Racer Spacer installed.
New cam plug installed.
Gene Berg forged straight-cut timing gears.
HD/HF Melling cast steel oil pump.
New push rod tubes.
Under head cool tin.
Engle Fk8 cam.
1.4:1 forged ratio rockers.
Dual Kadron carburettors with Scat adjustable linkage and cross bar.
Shorty aluminum intake manifolds.
Bosch Blue coil with aluminum off-set mount to clear Scat carburettor linkage.
Chromed cylinder head tin.
Original German dual port fan shroud.
Bosch 009 distributor with full tune-up, side ways outlet distributor cap, and finned aluminum sleeve.
Vented aluminum fuel pump black-off plate.
Electric fuel pump.
Finned aluminum Gene Berg Oil filler/breather tower.
Aluminum crank pulley.
Aluminum generator backing plate.
Chromed generator pulley with aluminum insert.
Chromed aluminum generator mounting stand.
Chromed dip stick. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Jul 02, 2015 4:46 pm Post subject: Re: info on this engine set up and builder |
theramny wrote: |
Mahle rings.
New push rod tubes.
Engle Fk8 cam.
Electric fuel pump.
The one thing I saw that was off with this build is an fk8 cam paired with heads that have HD ( presumed single springs). Please double check it. Single springs with an fk8 cam is a folly alone. 71 bus and type 1 engine? I thought 68 or 69 was last type 2 set up? Make sure it has 3 bolt carrier bosses if that style. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Thu Jul 02, 2015 4:48 pm Post subject: |
For a bus engine ???
Stay away! |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Thu Jul 02, 2015 4:49 pm Post subject: |
71 is the last year of the type 1 engine in a bus. That motor is begging for a pair of 40 idf's _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
mark tucker Samba Member
Posted: Thu Jul 02, 2015 5:08 pm Post subject: |
fk8 will work with single or duel. but I doubt it is what you want in a bus with a small engine like that and the heads I would think have duel springs but the springs may not work with the 1.4&fk8 but they should. but still thats not a buss engine....depending on what you want to do with it of corse |
Joe Bence Samba Member
Joined: March 14, 2004 Posts: 501 Location: San Diego, CA
Posted: Thu Jul 02, 2015 5:19 pm Post subject: |
Run.............. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Thu Jul 02, 2015 6:26 pm Post subject: |
Joe Bence wrote: |
Run.............. |
away.
lose the chrome shit, and the thin wall 92's are not ideal for a bus. The Kadrons are not suited for that combo..
The price may be right but the combination is all wrong. Thick wall 92's, ported stock valve heads, different cam and carbs would be a great bus motor. |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Thu Jul 02, 2015 6:27 pm Post subject: |
esde wrote: |
Joe Bence wrote: |
Run.............. |
away.
Why would anybody use thin walled 92's anymore? Just silly. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Thu Jul 02, 2015 10:02 pm Post subject: |
That would be a good engine for a sandrail or Dunebuggy to play around in, but totally wrong for a heavy Bus. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Thu Jul 02, 2015 10:38 pm Post subject: Re: info on this engine set up and builder |
theramny wrote: |
Mag 44 big valve machine honed heads with HD springs. CB 044 MAGNUM HEADS ARE GOOD...WHAT VALVE SIZES?
Dual oil relief German low mileage case. PERFECT.
Forged 92mm barrels and pistons. ASSUME MAHLE, SINCE YOUR RINGS ARE MAHLE? CONFIRM WITH SELLER.
Teflon wrist pin buttons, cc'd heads, deck height double-checked. CONFIRM THE CR?
Mahle rings.
Gene Berg forged straight-cut timing gears. GOOD PRODUCT.
HD/HF Melling cast steel oil pump. ITS OKAY, BUT SOMETIMES THEY LEAK. ALUMINUM PUMP MIGHT BE BETTER IN A BUS (EG. SCHADEK).
New push rod tubes.
Under head cool tin. STOCK DEFLECTORS, REAR TIN, ETC, WOULD BE BETTER THAN "COOL TINS".
Engle Fk8 cam. A BIT MUCH FOR A BUS, BUT LIFT IS NOT EXCESSIVE.
1.4:1 forged ratio rockers. CHECK FOR ACTUAL RATIO...SOME SPEC OUT MUCH HIGHER.
Dual Kadron carburettors with Scat adjustable linkage and cross bar. GREAT BUS CARBS. MIGHT NEED VENTURI SWAP TO MATCH ENGINE BETTER.
Original German dual port fan shroud. DOGHOUSE IS TOP NOTCH.
Bosch 009 distributor with full tune-up, side ways outlet distributor cap, and finned aluminum sleeve. CHINESE 009 OR BOSCH GERMAN/BRAZILIAN?
Electric fuel pump.
Finned aluminum Gene Berg Oil filler/breather tower. GOOD PRODUCT.
Depending on the price, there are some good parts in this engine. As others have noted, the combination is not quite what most would build for a bus, but you could make some mods if the price is right. How much is it selling for? _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Posted: Fri Jul 03, 2015 4:38 am Post subject: |
great feed back guy thank you ill be passing on this thing i might rebuild my 1600 to a 1641 with dual carbs for a little more power all im looking for is a boost to get up hills and pull my samm 12 aluminum boat on fishing trips |
