vanis13 Samba Member
Joined: August 15, 2010 Posts: 3099 Location: ABQ NM USA.... Except when not
Posted: Thu Jul 02, 2015 8:58 pm Post subject: What plastic type are the gauges and instrument cluster? |
What type of plastic in the instrument panel and gauges made of and what solvent could be used to fuse it back together?
I’m looking for the solvent, nothing like epoxy, JBweld, or super glue but the actual solvent.
I’m guessing its ABS and maybe acetone might be a good way to chemically bond it back together?
Cleaning up the cluster after the odometer fix and would like to put it back tidy. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Zeitgeist 13 Samba Member
Posted: Thu Jul 02, 2015 9:07 pm Post subject: |
I use an ABS cement intended for use with plastic plumbing. Works great |
Terry Kay Banned
Posted: Thu Jul 02, 2015 9:13 pm Post subject: |
It's polystyrene. _________________ T.K. |
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Fri Jul 03, 2015 10:09 pm Post subject: |
Acetone is what you are looking for. I used it to weld several little bits back together on not only the IP, but also my heater plenum. Just a small artist brush and acetone. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sat Jul 04, 2015 5:18 am Post subject: |
This is what I use - works quite well:
I get it at a local hobby shop.
I have not tried Acetone for this, the purpose made product seems thicker so possibly it gives you more work time.
In addition to full breaks, if there are fine cracks the glue can be applied to those and capillary action will pull it into the crack and effect a repair.
Be aware - in my experience the weld will seem to set up quite quickly (minutes) but you really want to wait overnight for it to have full strength. |
