Right turn signal won't turn on when headlight switch is on.
poorkollegekid
poorkollegekid is offline
PostPosted: Fri Jul 03, 2015 6:13 pm    Post subject: Right turn signal won't turn on when headlight switch is on. Reply with quote
L & R signal works when headlight switch is off. L signal works in both "on" positions of headlight switch. R only works when Headlight switch is off. Losing my mind. All other lights and signals work fine.
New Headlight switch and Relay didn't fix the problem.
Losing my cool.
1969 Fastback. Sad
Bobnotch
Bobnotch is offline
PostPosted: Sat Jul 04, 2015 11:34 am    Post subject: Re: Right turn signal won't turn on when headlight switch is Reply with quote
Losing my cool.
1969 Fastback. Sad
Double check your grounds at the tail light. Also have a look at the bulb and it's socket.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
