Mizan Samba Member
Joined: July 04, 2015 Posts: 36 Location: Seattle,Washington
Posted: Sat Jul 04, 2015 11:23 pm Post subject: DIY Two Tone |
Hi,
I've been getting a lot done on my Ghia this summer, and painting my wheels was on the list. Here's how I did it.
Before: https://www.flickr.com/photos/mizansomaniphotography/19418571132/in/album-72157655047119379/
Shopping List:
Simple Green
400 grit sandpaper
rustoleum filler primer-2 cans
(choose color)rustoleum gloss enamel spray paint-2 cans
Another can of a different color paint-2 cans
Rusoleum wheel clear coat-2 cans
blue masking tape(wide) 2 rolls
Step 1:
I deflated and masked the tires. After cleaning the wheels with simple green, washing, and letting them dry, I ripped off pieces of tape and tucked them in between the wheel and the tire. I then used larger pieces until most of the tire was masked from over-spray. Then I masked the valves, with small pieces.
https://www.flickr.com/photos/mizansomaniphotography/19238654599/in/album-72157655047119379/
Step 2:
I didn't want to wirebrush or sand the old paint off, so I used Rustoleum Filler Primer to get a smooth surface. I put on two thick coats of that.
https://www.flickr.com/photos/mizansomaniphotography/19418566512/in/album-72157655047119379/
https://www.flickr.com/photos/mizansomaniphotography/19429024281/in/album-72157655047119379/
Step 3:
After 24 hours(or more) I wet-sanded the runs in the primer, which was put on thick to fill imperfections. I ran a tack-cloth over that and painted the wheels with rustoleum gloss antique white, two regular coats.
https://www.flickr.com/photos/mizansomaniphotography/19418567322/in/album-72157655047119379/
https://www.flickr.com/photos/mizansomaniphotography/18804204913/in/album-72157655047119379/
Step 4:
After the paint was very dry, I masked the outside of the wheels by sliding small pieces of masking tape down the inside on their non-sticky sides until they touched the crack, then moving them over to stick on to the outside of the wheels. After the first line was masked, I masked the rest of the wheel, leaving only the inside.
Step 5:
I Painted the wheels with rustoleum gloss in safety red, a surprisingly perfect match to the red of my ghia. Two regular coats.
https://www.flickr.com/photos/mizansomaniphotography/19424807615/in/album-72157655047119379/
https://www.flickr.com/photos/mizansomaniphotography/18804201043/in/album-72157655047119379/
Step 6:
let those dry, then wait another day to harden, then remove masking tape everywhere except the tires. touch up any over-spray or under-spray with a brush.
https://www.flickr.com/photos/mizansomaniphotography/18802296774/in/album-72157655047119379/
Step 7:
After 3 more days of baking, apply rustoleum wheel clear coat, two light coats. let that dry and mount your new two-tone wheels!
https://www.flickr.com/photos/mizansomaniphotography/19429011491/in/album-72157655047119379/
https://www.flickr.com/photos/mizansomaniphotography/19424802775/in/album-72157655047119379/ |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Jul 05, 2015 7:59 am Post subject: |
Steel wheels look better two-tone! These are original paint Beetle wheels.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
