Randys garage Samba Member
Joined: July 11, 2011 Posts: 24 Location: Cookeville,Tn.
Posted: Sun Jul 05, 2015 6:06 pm Post subject: Oil pump to cam question |
Trying to track down a clacking sound in my
Type 1. 1914, drd cam etc. Kind of decided it might be a sloppy
Fit between the slot in the cam and the flats
On the driven oil pump gear. Sound possible?
I don't think the wrong pump could be the issue
As i don't believe a dished cam oil pump would
even fit. I did have grind some of the oil pump
to clear the bolt heads that hold the gear to the cam
Sounds quite a bit like valve train noise but all that
looks good |
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Sun Jul 05, 2015 6:58 pm Post subject: |
Don't know about the noise but it is possible for the cam and oil pump to get worn big time... mine are.
_________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
Posted: Sun Jul 05, 2015 7:56 pm Post subject: |
Wow |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Sun Jul 05, 2015 8:25 pm Post subject: |
Is a 30mm schadek. Flat gear style
Can't see any wear, just doesn't seem a
To be a good fit |
Posted: Sun Jul 05, 2015 8:30 pm Post subject: Re: oil pump to cam question |
often a faint clacking is the cam gear teeth wearing, and it's no longer tight in the teeth of the crank gear. Check it. It will often do this with
mag cam gears
woodruff key too tight into the crank (swells the crank, swells the crank gear, which is then no longer round)
And some cheaper cam gears aren't round out of the package.
30mm oil pumps are going to wear faster than smaller ones, since they are under more loading (higher pressure). They are also fairly constantly loaded, so won't make noise like a cam gear, even when severely worn. The tang eventually just spins off and you have no oil pressure. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
philthy Samba Member
Posted: Mon Jul 06, 2015 2:10 pm Post subject: |
If a person is using anything larger than a 21/26mm pump, it wouldn't be a bad idea to rent or buy a crank pulley puller and pull the pump every 2nd oil change. The process is simple and gaskets are cheap. Slap the pulley back on with the pump out and you can check by hand how loose the gears mesh. Sure it's a bit overkill, but is it really? _________________ 74 Baja 1600 Dual ICT |
6718nellotinnirello Samba Member
Posted: Wed Aug 05, 2015 5:13 pm Post subject: cam and oil pump for 71 block |
the project I bought came with a cam which is a 3 rivet flat, didn't belong to that block. the block I have is an ae. will I be able to use that cam and what oil pump do I use. seems that all the oil pump made for 71 blocks are for 4 rivet dish cams. thanks, I usually get a decent response. |
sloboatnova Samba Member
Joined: September 20, 2009 Posts: 989 Location: Broken Arrow, Ok
Posted: Thu Aug 06, 2015 12:04 pm Post subject: |
You can use either cam in a 1600 platform as long as you order the correspoding pump. When you read a pump description, it will tell which cam it's for. All aftermarket cams are 3 bolt style.
Decide on a cam first, then buy a pump to match. _________________ Ms Hoover, I glued my head to my shoulder.
3BT Baja build page
http://www.thesamba.com/vw/forum/viewtopic.php?t=417564&highlight=3bt+baja |
