horsetrader Samba Member
Posted: Sun Jul 05, 2015 11:37 pm Post subject: Novice Painter Questions |
I'm in the process of painting a 72 VW bug. When I got the bug there was no trim on it. What is the best way to fill in the trim holes? I have counted 40 trim holes to fill in!! So far I have started sanding the Bug, Should I fill in the holes before putting on greay primer? If so, what is the best way? Is there any shop or independent auto painter that could spray it after I put on the primer. If you know of a shop or painter, that would not charge a arm and leg, please give me a referral to them. I'm retired and money is tight. Any help would be appreciated. Thanks, VW Jim. |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Mon Jul 06, 2015 12:19 pm Post subject: |
The trim on a classic beetle is the best part.
I would weld them but I go to sleep at night with a mig nozzle in my hand. A different method is to use a scratch awe that just barely fits in the hole and put a divot in the panel striking it with a hammer. That way there is a 'bowl' to hold the filler. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Rex lucy Samba Member
Joined: April 10, 2008 Posts: 497 Location: pleasant plains arkansas
Posted: Mon Jul 06, 2015 4:46 pm Post subject: |
the last medium you want to use is bondo. draws moisture and allows rust at every hole. I use a fberglass patching putty purchased a walmart I use an awl and hammer to make small indent then fill with the fiber putty then bondo over that. |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
