dutchman Samba Member
Joined: August 19, 2004 Posts: 38 Location: Louisville,ky
Posted: Mon Jul 06, 2015 2:37 pm Post subject: 97 golf road noise |
My 97 golf has started to make a fairly loud, annoying noise. Gets worse with increased speed. Sounds as if coming from rear axle. Rt rear wheel if I had to guess but hard to tell exactly. It did this before for some time and went away. Is now back again. Is sort of a loud humming or whirring sound. Any ideas or suggestions on what I should check? _________________ "80% of life is just showing up" Woody Allen
65 beetle |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Mon Jul 06, 2015 8:36 pm Post subject: |
Bearing, inner or outer. |
helowrench Samba Member
Joined: August 27, 2003 Posts: 567 Location: dallas texas
Posted: Tue Jul 07, 2015 8:39 am Post subject: |
ps2375 wrote: |
In the words of Cousin Eddy, "Bingo"
Do not drive it much until you fix it, as the inner race can overheat and weld itself to the axle, which makes it a more expensive job, (stub replacement, worst case) _________________ Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Tue Jul 07, 2015 9:24 am Post subject: |
As you drive the vehicle, does the noise change as you turn? If it does then it's probably a bearing, if not, you could possibly have scalloped (or cupped) tires. You can run your hand over the tread & feel if the surface is even or if it has dips the in the tread (will usually be on inner edge). If no abnormalities are detected, jack up the suspected corner & spin the wheel, you should be able to hear the noise, if so, replace the bearings. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Jul 07, 2015 9:29 am Post subject: |
Before you run your hand over the tread, make sure there isn't any sharp debris or belts protruding out of the tread. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
ps2375 Samba Member
Posted: Tue Jul 07, 2015 1:47 pm Post subject: |
Also a good time to replace the inner bearing seal. |
Posted: Tue Jul 07, 2015 3:12 pm Post subject: |
Replaced all rear wheel bearings today. Was a pain, but it seems to have fixed the problem. I drove the car a short distance and noticed no noise. Thanks for the help. _________________ "80% of life is just showing up" Woody Allen
65 beetle |
