madman4 Samba Member
Posted: Mon Jul 06, 2015 4:51 pm Post subject: 914 Differential in 901/02 trans |
Hi,
Could I install a 914 differential to replace de bad one in my 901/02 ?
The left bearing had turned around the diff ...
Or could you give me the part number of the diff, I was not able to find it ...
Thanks
Pat _________________ Have a right Foot ???
USE IT !!!
[color=6633FF]MON BLOG !!![/color] |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Wed Jul 08, 2015 5:59 pm Post subject: |
Is that 45mm or 50mm? (the burned bearing flange)
Early 901 is 45 mm. 914 is 50mm. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Thu Jul 09, 2015 5:15 am Post subject: |
gears wrote: |
Early 901 is 45 mm. 914 is 50mm. |
Thx for your replay Ray.
it's 45mm.
But the bearing was a LM603049, Id45.24mm, may be the problem was here ?
I dont find any bearing that match Id50mm with the OD of 77.79mm of the LM603049 ...
What are the real size of the bearing for the early 901 diff ?
Thx
USE IT !!!
gears Samba Member
Posted: Thu Jul 09, 2015 6:50 am Post subject: |
I have none of it in my hand, but early 901 is 45mm, while 914 (and late 901) are 50mm. So no, the 914 diff won't fit your early 901. Something sounds odd with that bearing ID size .. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Posted: Thu Jul 09, 2015 7:00 am Post subject: |
This si what I thought ...
Yep something is wrong but the od in the side plate is 77,80mm.
And the only bearing available here in Europe with 77,79od is 45,24id ... _________________ Have a right Foot ???
USE IT !!!
