Bigdaddychopshop Samba Member
Posted: Wed Jul 08, 2015 4:55 am Post subject: First time rail |
Picked this bugger up on Ebay- so far, what I know is this:
1500cc 63-65 Type 3 motor
AH transmission 4.125:1
Turning brakes, rear only, no fronts.
Seats are WAY narrow.
Most of chassis work looks OK, needs some touch up, but the "tire protectors" (triangles coming off sides) are hack. Seat belt mount, hack, caliper mounts, ditto.
Give $800, runs, but needs dug into. It appears to be to possibly be a Berrien 295 chassis (wheelbase is 95").
Can some one give me any info, what to look for, possibly what rear calipers are used, and what, other than mentioned, are issues seen?
I intend to remove the front bumper, and the side guards (make it easier to get in and out) and do some stiffining. Redo all the hack junk. I'm a guy who loves to know what I am working with, so any insight would be great!
Plan to use mainly on road, new to VW so no info you have is "too simple".
Posted: Wed Jul 08, 2015 4:56 am Post subject: |
Posted: Wed Jul 08, 2015 4:58 am Post subject: |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Wed Jul 08, 2015 5:22 am Post subject: |
Not sure I'd trust that rear brake setup the way it is.... Those brackets should be bolted to the axle carriers, not tacked onto the rear arms...
Looks like a fun project though, worth the $800 |
terryly Samba Member
Posted: Wed Jul 08, 2015 5:48 am Post subject: |
Those tri angle pcs are tree bars. I have them on my Baja buggy. Used them, bent them, fixed them ,used them again etc etc. One of the parts I have trouble keeping paint on.
Terry |
Posted: Wed Jul 08, 2015 8:13 am Post subject: |
Bashr52 wrote: |
Thats what I was calling "caliper mounts"- junk. Beyond junk, and totally unsafe.
As for the treebars (or whatever they are called) the steering shaft and waterpipe reinforcement is comical at best, and the fact they are only welded on the top is a bit much. I can't see needing them with mostly street use, but I may keep them, if I do, they will be reduced in size (they stick out 3-4" beyond the rear tires, making it a pain to get in/ out of the car).
Thanks for the info guys! |
rossl1 Samba Member
Joined: May 13, 2015 Posts: 24 Location: Simpsonville, SC
Posted: Thu Jul 09, 2015 11:20 am Post subject: |
I just bought a Rail with the same frame. Starting off with the hack jobs is a good place to start.
Since this is your first rail take it slow and try and work on one thing at a time. I have found if I try and tackle two things at once I start to get impatient.
Looking at the pictures it looks like you have the front drums. You need to hook up the lines and use them. Replace the wear parts as necessary. Move the battery to the front. Some added weight will help traction up front when trying to steer.
Is your floor tabbed? I don't see any in the picture. If it is screwed in the rail it is best to weld the holes shut and use tabs. Don't want it rusting from the inside out! It on my to do list as well. |
Posted: Fri Jul 10, 2015 5:14 am Post subject: |
rossl1 wrote: |
Thanks for the great info! I have not looked at the flooring, but it appears to be welded in, not my idea of a great plan, but hard to correct. As for the front brakes, they are just the drums, no backing plates or "innerds". Sucks for sure. Any idea what the rear calipers are, I'd perfer to buy the correct brackets, but I do fab work, so not a bid deal if they are non-standard.
Thought about moving the battery and fuel tank up front, my pops said, "yeah thats a GREAT idea, battery acid and fuel all over you in an accident". Kinda hard to argue the logic, but I still havent made up my mind. Battery has got to move, the "tray" is flinsy and scary. Also would like to get some more room. I'm a big man, and the seats will have to be changed anyway.
Thanks again. |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2649 Location: West Coast (Michigan's)
Posted: Fri Jul 10, 2015 5:16 am Post subject: |
I'm not so sure that's a good way to start. A knockdown weld-together berrien kit is around $300 new and you know there aren't any rust holes starting hidden inside the tubes.
Looks like you'd be best served to tear that thing down to the last bolt and start sand blasting and arcin and sparkin' _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Posted: Fri Jul 10, 2015 9:24 am Post subject: |
ORANGECRUSHer wrote: |
Looks like you'd be best served to tear that thing down to the last bolt and start sand blasting and arcin and sparkin' |
Thats an interesting thought, but what would make you think there would be issues? I am very confident this was not a knockdown build (but I could always be wrong). The chassis welds are virtually perfect, just the add-ons that are crap. But perhaps you are right. $300 is pretty cheap, got to admit, a bit suprised to hear that price. I have access to an eddy current machine (which will show issues in tubing), but time-wise you may be onto something. Going to do some teardown this weekend (I hope, you never know what it may bring). That will tell a story for sure.
I see lots of guys on here resurrecting stuff that looks as bad if not worse, but if that cost holds, that may in fact be a good route. Hadn't really looked, didnt figure it was needed. Thank you! |
CBFLbikerider Samba Member
Posted: Fri Jul 10, 2015 12:52 pm Post subject: |
Bigdaddychopshop wrote: |
rossl1 wrote: |
Thanks again. |
Had the same type setup on my rail. found total innerds for the front drums here on Samba for a great price. Took a bit of time to find what I wanted,but it was worth the wait. Next is my trans swap out..... |
dustymojave Samba Member
Posted: Fri Jul 10, 2015 2:57 pm Post subject: |
More like $400 plus shipping for a Berrien frame these days. Plus you would need a VW torsion housing.
http://www.acmecarco.com/berrien-buggy/sand-rails/2-seat/warrior
Still a great price. Considering that in the mid 1970s I paid $450 for my Hi Jumper rail frame including torsion housing and welded. Fiberglass buggy bodies then were about the same as my frame. Now they're $2500. Considering a new full size well equipped pickup then was $5000, and now it's more like $50K, I'd say $400 for a frame now is a good price.
That said, I really don't see need to replace the frame you have. Especially for mostly pavement use. _________________ Richard
SoCalBajas Member
rossl1 Samba Member
Posted: Sat Jul 11, 2015 7:33 pm Post subject: |
I dont know what you could pick up used drum set up for but Rockwell.com is a great place to find some cheap parts. I just rebuilt my rear drums for cheap. I haven't had a chance to give them a good test but visually they looks good.
Wheel cylinders $7
Drum $35
Pads $10-$15
Hardware $5 |
rossl1 Samba Member
Posted: Sat Jul 11, 2015 7:34 pm Post subject: |
That's Rockauto. Stupid auto correct |
rossl1 Samba Member
Posted: Tue Jul 14, 2015 4:34 am Post subject: |
Thanks for the info guys.
Looked at this a bit more (it was a CRAZY busy weekend), and the floor is welded to the tubing. Not ideal, but well done none the less. I eddy currented some of the tubing, and no issues at all. Asside from the corrective action mentioned, the frame will stay the same. pulled the seat covers off, and figued out why my big butt wont fit- 15" seats, older fiberblass style. Those are going away.
Apologies for the slow progress, but summer is busy with 5 kids and filling in at the church some. Real work will hopefully commence soon.
And thanks for the info on the brakes- backing plates seem to be the largest issue. |
Posted: Mon Jul 20, 2015 6:56 am Post subject: |
Got a bit of work done (removed the Tree guards that were barely attached) kinda scary how bad the weliding was, took about 30 seonds a side, but the bracing was a steering shaft and water pipe lol. Still need to clean up, but pleased. Also removed the VERY narrow seats (15") and the battery tray. Lots of Crap workmanship.
Plan to raise the roof bars as I am 6'1" and 340.
So I also changed the oil (full of water) and ran it a bit. Or tied. I have a couple questions.
This has a 28 PICT-1 carb, but it has the air cutoff solinoid (only saw in diagrams for the 30), it is not hooked up, could this be part of the issue? I have ordered a Chiltons, and hope there is a wiring diagram so I can figure out what it oks to along with the Electric choke.
Is this normanl for this carb?
Also, I noticed there is a broken stud holding the intake on at the head port. I will get this corrected.
I have ordered a basic tune up kit, not sure if it is right or not, hard to tell on Rock auto, but it is for a 009 dist. Hope it will work. Also got a carb rebuild kit, some plug wires, fuel pump (not crazy about the electric).
I am going to need some other items, but wanted to reach out. Need one wheel, on the front, and shocks (perhaps stock on the front?)
Looking for advise. |
Aerindel Samba Member
Joined: May 30, 2015 Posts: 459 Location: Western Montana
Posted: Mon Jul 20, 2015 2:05 pm Post subject: |
Looks like your off to a good start. _________________ Homemade woods/street, bug out rail. IRS, Balljoint front end. 1967 1600cc DP, Weber 32/36 progressive, tri-mil quiet pack. Rear only cutting brakes.
http://www.thesamba.com/vw/forum/viewtopic.php?t=630046 |
Posted: Tue Jul 21, 2015 12:51 pm Post subject: |
28 PICT-1 carb is for 1961-1965 1,200cc 40hp engine. Please post pics of the end of the intake manifold where it meets the head (either side of the engine). That will tell us if you have a 1200cc or a 1500/1600cc engine.
My 1965 Bug I bought from the original owner in 1973 came with a 28 PICT-1 carb, but it did not have an idle cutoff solenoid. Someone may have replaced the pilot jet in yours with a cutoff solenoid for a later carb. Could work, I've never tried it. Idle cutoff solenoid and electric choke both connect to the ignition switch side of the coil. 16ga wire works. No smaller. Use insulated slip connectors to make it less likely to short out.
009 distributor fits in 1200cc, but uses different points, condenser, rotor, and cap than vacuum advance distributors for 1200, 1300, 1500 or 1600. So if you have a vacuum advance, the 009 tune up kit will not work. Plug wires are the same. Spark plugs may have different length thread. Make sure the plugs are correct for your heads. I've encountered rebuilt heads from GEX and others which have different plug holes from one cylinder to the other on the same head. Different thread diameter and different thread length. So beware.
Be careful how you raise the roof height. I've seen some dangerously bad work on that. Make sure the seats chosen sit as low as they can without hanging your butt out the bottom to drag on any rocks or tree roots, etc. Choose seats which set your butt low in the 1st place. mount the seats well. I've had to repair broken and bent seat mounts for big guys like you in a couple of cars. _________________ Richard
SoCalBajas Member
Posted: Tue Jul 21, 2015 12:53 pm Post subject: |
Rock Auto is the place where I found the very best retail price for KYB shocks the other day. _________________ Richard
SoCalBajas Member
