akear Samba Member
Joined: August 18, 2013 Posts: 359 Location: Los Angeles
Posted: Mon Jul 13, 2015 7:23 pm Post subject: Clutch Recommendations |
Clutch went out; started slipping. Its not the cable or adjustment as I have free play. Going to order a new kit but not sure whats best. Car is a stock '70. I see BusDepot has a Sachs Brazil complete kit (disc, pressure plate, TO bearing) with spring disc for $110, which seems like a very good deal. They also have a Sachs rigid disk kit for $132. Which one? Or something else? Don't want to skimp on parts but also don't want overkill or to sacrifice smooth operation. Thanks. |
danielsan Samba Member
Joined: September 18, 2008 Posts: 802 Location: Carson City, NV
Posted: Mon Jul 13, 2015 7:43 pm Post subject: |
This is a question like oil -- everyone has an opinion and everyone thinks their opinion is correct. My answer -- on a stock engine go for a sachs spring loaded disc. If you often shift on hills often go for a sach pressure plate and a 'super disc'. If you have a huge engine go for a bus pressure plate and a super disc.
http://www.cbperformance.com/ProductDetails.asp?ProductCode=1359
The super disc lasts much longer but I prefer the feel of the spring loaded. And, when my rigid disc gives out I will switch back to spring load.
Confused? When in doubt, go stock. |
akear Samba Member
Posted: Mon Jul 13, 2015 9:14 pm Post subject: |
Okay, with 1 vote in I'm going with the Sachs spring loaded disc kit. I've found cheaper stock kits -- and also more expensive ones -- that don't say what brand. I do want to know what I'm buying. I'm still curious why people choose the rigid disc over spring. Or maybe you shouldn't with a stock set-up? From what I've gathered the spring disc is smoother but I'm still not sure why to pick one vs the other. |
Posted: Mon Jul 13, 2015 11:54 pm Post subject: |
Partially it is you like what you like. When I jump from a rigid disc vw to spring loaded vw it takes me a few shifts to adjust. For big engines -- there is less chance of breaking the disc, the super disc has more grip, and you can shift a rigid disc fractions of second faster (also means you are more likely to give yourself trans problems) |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Tue Jul 14, 2015 6:50 am Post subject: |
I noticed after 10,000 miles, my Sachs Stock (well new stock) Brand pressure plate got "soft" in my beetle.
It still grabs great... its just the clutch pedal got REALLY soft.
Diaphragm style. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Tue Jul 14, 2015 7:22 am Post subject: |
I was told that a spring clutch was more forgiving with those new to driving a clutch. If you were familiar with a clutch to use a rigid one instead. I guess the spring clutches have a softer pedal feel? Mine actually had a rigid one come out of it. _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
Bruce Samba Member
Posted: Tue Jul 14, 2015 11:34 am Post subject: |
The pedal effort or feel isn't affected by the disc.
The spring center discs engage smoother than solid discs, that's why all new cars today with a manual g'box use them.
When you have a big hp VW engine, the spring center discs sometimes can't take the load and come apart. Not a problem with stock engines.
Another reason most pick a solid center disc is that they are cheaper to manufacture, and the majority of VW owners are CHEAP! _________________
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Tue Jul 14, 2015 12:01 pm Post subject: |
Ahh... the debate: Solid disc or sprung (Marcel) disc? ...it's an age-old argument.
I use a sprung disc on stock motors, and solid/rigid center disc on 1776cc-up.
I've had very good success with this setup - http://www.clutchcityonline.com/vw_type_1.htm
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
akear Samba Member
Posted: Sat Jul 25, 2015 1:52 pm Post subject: |
Update- Ended up getting the Sachs stock clutch kit with spring loaded disc from Kaddie Shack in Pasadena. Jeff there is super nice and helpful and they have a pretty decent inventory of stock as well as aftermarket parts. I'm liking the new clutch too! |
c21darrel Samba Member
Posted: Mon Jul 27, 2015 6:03 pm Post subject: |
Nice info, thank you!!!! _________________ -Jared
Posted: Mon Jul 27, 2015 9:32 pm Post subject: |
Agreed. Good decision. |
