blatzer Samba Member
Joined: June 27, 2007 Posts: 358 Location: Austintatious- aka ATX
Posted: Fri Jul 24, 2015 5:53 am Post subject: door panels |
i have tried to glue the skin back down on my door panels with Weldwood Contact Cement and it aint workin! Is there another product that might work better that i dont know about? |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Fri Jul 24, 2015 6:37 am Post subject: |
3M super adhesive spray. Try softening the vinyl with a hair drier first. _________________ 1976 Westy
1966 Beetle |
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1399 Location: Cambridge, MA
Posted: Fri Jul 24, 2015 7:51 am Post subject: |
Bala wrote: |
3M super adhesive spray. Try softening the vinyl with a hair drier first. |
That's what I used, "Super 77" is what it says on the can. And hot glue on the edges where it wraps around. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Bala Samba Member
Posted: Fri Jul 24, 2015 8:09 am Post subject: |
Binder clips work great at holding the vinyl in place while it cures. Use a lot of them.
1966 Beetle |
alikatcraig Samba Member
Joined: September 09, 2007 Posts: 556 Location: Anaheim, CA
Posted: Fri Jul 24, 2015 11:54 pm Post subject: |
Weldwood is usually OK if it is the solvent based one - the 'green' one is BAD. A hot glue gun will stick the edges down on the back to keep everything in place. _________________ 1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug |
72camper Samba Member
Posted: Sat Jul 25, 2015 3:09 am Post subject: |
We used Permatex Body Shop Heavy-Duty Headliner and Carpet Adhesive from Advance Auto. |
curtis4085 Samba Member
Posted: Sun Jul 26, 2015 8:05 am Post subject: |
3m 90!!
Helps to sand off the old glue on substrate first. Spray new glue on both the panel and vinyl let tack and the vinyl should stick. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
grandpa pete Samba Member
Posted: Sun Jul 26, 2015 8:24 am Post subject: Re: door panels |
blatzer wrote: |
I would like more info on how Weldwood " isn't working "
Are you gluing BOTH sides and waiting for it to dry BEFORE you put the surfaces together ???
If your fabric or cardboards are tearing it's not the glue _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Tcash Samba Member
Posted: Sun Jul 26, 2015 10:36 am Post subject: |
curtis4085 wrote: |
3m 90!!
Helps to sand off the old glue on substrate first. Spray new glue on both the panel and vinyl let tack and the vinyl should stick. |
This is the trick.
You can use thinner to strip the old glue as well.
Spray a light even coat. If it is too thick it will not hold.
For those hotter climates.
http://www.dap.com/product_details.aspx?BrandID=50&SubcatID=9
Good Luck
Tcash |
TMI Products Samba Member
Joined: February 14, 2014 Posts: 744 Location: Corona, Ca
Posted: Mon Jul 27, 2015 10:32 am Post subject: Re: door panels |
grandpa pete wrote: |
blatzer wrote: |
patience is a must. I used to never wait for the glue to tack up and the fabric always come loose. _________________ Mario De Leon
1965 Turbo Mustang Fastback
1966 Type 3 Fastback
VW Division Sales Manager
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Posted: Mon Jul 27, 2015 8:24 pm Post subject: |
thanks lots of good tips ya'll
i admit there was a lot of old glue on there |
