2T2-Crash Samba Member
Posted: Fri Jul 24, 2015 12:14 pm Post subject: Home made Burl shift knob and face plates installed |
I found a beautiful chunk of apple burl and decided to use it to make a shift knob and new face plates for my gauges and fuel guage. I haven't made the plates yet but here's the shift knob, it's in it's third coat of shellack right now
My dad has a 67 as well and I'm betting he's going to make one for his now. LOL
grandpa pete Samba Member
Posted: Fri Jul 24, 2015 12:49 pm Post subject: |
LOL.
That's my dad spinning the wood, I've never used the lathe and truth be told he loves wood crafting so much he probably wouldn't let me anyhow.
I've been doing the sanding and coating on it. |
UberSlowWagen Samba Member
Joined: May 31, 2015 Posts: 10 Location: Vancouver, WA
Posted: Fri Jul 24, 2015 5:17 pm Post subject: |
turned out awesome! im just about to start a superior steering wheel resto out of wood and want a wood shift knob to go with it. _________________ Buyer responsible for shipping cost. I work long hours so will ship on days off. |
far rider Samba Member
Joined: August 30, 2005 Posts: 772 Location: Rutland, VT
Posted: Fri Jul 24, 2015 6:42 pm Post subject: |
nice! what did you use for an insert? _________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
Posted: Fri Jul 24, 2015 7:36 pm Post subject: |
far rider wrote: |
nice! what did you use for an insert? |
I cut apart the cheap aftermarket shift knob and am using it after sanding it down. |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Fri Jul 24, 2015 8:03 pm Post subject: |
Like!
_________________ -Bruce
An ounce of prevention is worth a pound of cure. |
VICS94HB Samba Member
Joined: May 13, 2015 Posts: 89 Location: Los Angeles, CA
Posted: Fri Jul 24, 2015 9:43 pm Post subject: |
can you make me one. how much? |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Jul 25, 2015 4:44 am Post subject: |
Nice.
The more exotic and grainy the better IMO.
Once installed... post in the topic below for a fresh bump.
http://www.thesamba.com/vw/forum/viewtopic.php?t=486841
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Sat Jul 25, 2015 6:25 am Post subject: |
I made one like that from a dining table leg.
Can your dad make me a new table leg ?
Just joking, nice, and I see dad had at least "some" eye protection. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat Jul 25, 2015 10:20 am Post subject: |
My dad isn't ready to start turning them for sale at the moment, partially because we need to figure out a better option for the insert, also because we are not sure what to sell them for. Apple burl (any burl really) is expensive and the piece we did that with was one I got for a steal at a garage sale. I'll let you guys know if he decides he wants to make and sell for sure. |
Posted: Sat Jul 25, 2015 6:24 pm Post subject: |
Jon's62 Samba Member
Posted: Mon Jul 27, 2015 9:12 am Post subject: |
Impressive work! |
arizonabuckeye Samba Member
Posted: Mon Jul 27, 2015 10:05 am Post subject: |
Man that is good work. Turning burl is no easy task.
For the inserts you could get some tubing with the right I.D. to cut the correct size threads. The insert is what like 3/4"? Cutting threads even in some mild steel would only take like 5-10 mins max. Then just epoxy that in. I bet with some looking you could probably find threaded tubing or threaded inserts that you could just pop in.
Maybe something like this:
https://www.fastenal.com/products/fasteners/furnit...0Nuts%22|~ |
Posted: Mon Jul 27, 2015 3:26 pm Post subject: |
My biggest problem now is cutting the holes for the gauges... Not the capability but actually cutting it because I lose a lot of pretty burl, which is rough to a wood lover.
I'm considering getting the chrome trim that originally went there, installing the wood with the trim, then rewording the gauges under the dash in a metal bracket.
I'm torn. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Mon Jul 27, 2015 3:52 pm Post subject: |
Quote: |
I'm considering getting the chrome trim that originally went there, installing the wood with the trim, then rewording the gauges under the dash in a metal bracket. |
Do that! Such a grill treatment is rarely seen.
Do you have enough burl for a matching glovebox cover?
You can also get a small gauge panel that fits into the stock radio opening. One of the metal fab shops that works on VWs sells them. |
Posted: Mon Jul 27, 2015 10:38 pm Post subject: |
Rome wrote: |
I wish I had enough for the glove box but I don't. I had enough to make one more set, which I gave to my Pops so he can make his 67 a set.
My radio panel was cut all to shit for a modern stereo by the PO. |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Wed Jul 29, 2015 12:35 am Post subject: |
very nice! _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Posted: Wed Aug 05, 2015 9:19 pm Post subject: |
I have the square cut out for the fuel gauge, just need to give it the three coats of Shellac and then figure out how the hell I am going to mount the wood pieces to the dash.
I don't like the idea of having screws showing, even if they are polished brass.
Any ideas? |
Rome Samba Member
Posted: Thu Aug 06, 2015 3:36 am Post subject: |
3 ideas come to mind right away:
For the smaller piece that contains the fuel gauge, won't the stock fuel gauge hold the panel to the dash by itself? That is, you push the gauge thru the face of the panel, take the assembly to the dash, then install the big U-clamp onto the gauge's retaining post from the trunk-side of the dash? The clamp's feet rest against the body's sheetmetal? Hold the clamp to the gauge with the knurled knob(s)?
2nd idea- an upper and lower strip of hook&loop fastener material, maybe like 3" long. Get some that is not too thick so that the wood does not sit far back from the dash surface.
3rd idea- 2 small dabs of clear silicone adhesive along the tops and 2 more along the bottoms of the wood, then use painter's tape to hold the wood in place overnight until the silicone cures. Enough to hold it, but enable pulling it off in the future in case of repairs or other access. You can test the size of the dabs using trimmed-off excess pieces of wood on some spare metal. Push the wood to the metal to squeeze out the silicone somewhat, just like you'd do on the car. |
