Rear bearing removal
roymartian
roymartian is offline
PostPosted: Sun Jul 26, 2015 12:31 am    Post subject: Rear bearing removal Reply with quote
Tried to make a simple bearing puller today as Haynes diagram but very frustrated and not working.
Any tips on removing rear wheel bearings and also safely re-installing new bearings.
Thanks
ian macdowall
ian macdowall is offline
PostPosted: Sun Jul 26, 2015 3:36 am    Post subject: Reply with quote
I once borrowed a genuine VW tool from an ex vw mechanic, it made rear bearings so easy to remove, unfortunately I had to return it! The only way I have found is to tap the axle inwards with a mallet and then work the bearing off slowly.
'51 Beetle Deluxe
'52 Barndoor Deluxe
roymartian
PostPosted: Sun Jul 26, 2015 4:41 am    Post subject: Reply with quote
ok thanks, i can see small gap between bearing and the rear plate - should the bearing be seated in the rear part / plate, maybe pulls into on torque of castle nut ?
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Sun Jul 26, 2015 5:35 pm    Post subject: Reply with quote
Yes, this is how I did it also... noticed that the local parts store lends tools, including a few different pullers... have not inquired.
This method does work.
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Mon Jul 27, 2015 7:52 pm    Post subject: Reply with quote
Pull the splined axle shaft out using your hand. It should slide out 1/4" or so.
Get yourself this style of vice grips:
Clamp it around the outer race of the bearing and tight as you can and against the casting lip.
Put the axle nut on upside down and use a soft brass or similar hammer to drive the axle shaft back in towards the tranny. This should cause the bearing to be forced further off the axle shaft.
Repeat as many times as needed until you can get a proper puller on it, or it comes off.
roymartian
PostPosted: Tue Jul 28, 2015 5:08 am    Post subject: Reply with quote
thankyou - will give it a go, what sort of press fit are they - easy to remove ?
Low Bräu
Low Bräu is offline
PostPosted: Mon Aug 03, 2015 2:27 pm    Post subject: Reply with quote
The only way I have ever changed those bearings is with the proper puller. Since you don't have one, you could probably tack weld a piece of metal, or tubing, to the bearing and pull it out with a slide hammer. Or you could try grinding two notches in the outer race that would allow a two fingered puller to grab it. Just a few ideas, good luck.
Independent German Auto
671 Fern Drive
Merritt Island, FL 32952
(321) 449-4665
Specializing in repair and maintenance for Porsche, BMW, Mini, Audi, and Volkswagen.
1952 Standard Beetle
1960 SO-23 Westfalia
1961 L-380 Turkis Deluxe Beetle
1985 Vanagon Country Homes Camper (work in progress - EG33 swap)
roymartian
PostPosted: Sun Aug 09, 2015 12:56 am    Post subject: Reply with quote
Does anyone have pics of correct tool please, had disastrous day trying to get bearing off axle.
Bearibng puller bought locally but legs too short so thinking of modifying...
IN2VWS
IN2VWS is offline
PostPosted: Sun Aug 09, 2015 2:56 am    Post subject: Reply with quote
Hey Roger,
I don't have a factory tool, but I used this last time. Worked a treat.
*Note - it does ruin the bearing you are removing, as you have to drill the cage to use the tool.
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³
roymartian
PostPosted: Sun Aug 09, 2015 4:51 am    Post subject: Reply with quote
Thanks John, where did you buy from please.
fyi - engine landing next week fingers crossed Shocked
IN2VWS
IN2VWS is offline
PostPosted: Sun Aug 09, 2015 5:09 am    Post subject: Reply with quote
I think I got it from Bearing Wholesalers in Bayswater.
Most bearing place should have them.
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³
Ovally
Ovally is offline
PostPosted: Sun Aug 09, 2015 1:55 pm    Post subject: Reply with quote
I used this one from Draper 43136 (large insert bearing puller).
Works the same as the TRAX puller.
http://www.drapertools.com/product/43136/Expert-Large-Insert-Bearing-Puller-Kit
Best regards, Armand
roymartian
PostPosted: Sun Aug 09, 2015 3:14 pm    Post subject: Reply with quote
Thanks Guys
