Trekker182 Samba Member
Joined: February 14, 2014 Posts: 99 Location: United Kingdom
Posted: Sun Jul 26, 2015 1:13 pm Post subject: 1966 Beetle Doors |
I am restoring/rebuilding a 1966 Beetle which was someones unfinished project. We have most of the parts but the doors are missing. Can anyone tell me if doors from other years will fit and if so which years.
Thanks
Don |
Underdog65 Samba Member
Joined: October 07, 2007 Posts: 143 Location: Lake City, PA
Posted: Sun Jul 26, 2015 1:29 pm Post subject: |
65 doors will fit _________________ Look off in the distance it's a bird it's a plane no it's a frog no it's just little old me Underdog65 and my Sweetpolly passing your way. |
Posted: Sun Jul 26, 2015 1:33 pm Post subject: |
Underdog65 wrote: |
65 doors will fit |
Thanks for the reply, I take it that later doors will not fit? how about earlier than 65? |
Posted: Sun Jul 26, 2015 1:37 pm Post subject: |
I think it's a two year door but I my be wrong someone will tell you.good luck with your project. I found four or five sets of door for a 65 and 66 in the classifieds _________________ Look off in the distance it's a bird it's a plane no it's a frog no it's just little old me Underdog65 and my Sweetpolly passing your way.
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Jul 26, 2015 1:41 pm Post subject: |
Correct a 2 year only door. 1965 and 1966.
Larger windows, shorter door panels, slider style latch and ice pick inside door handle.
Now..not all countries use the same body.. SO it depends on what you have and where the car was originally destined for.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Posted: Tue Jul 28, 2015 12:54 pm Post subject: |
VOLKSWAGNUT wrote: |
Technically a 2 year only door. 1965 and 1966.
Can anyone tell me why it's only doors from 65/66 Beetles that fit a 1966? is it the shape of the door, the hinges, handles etc. are all of these? I am really struggling to find 65/66 doors in the UK. |
Posted: Tue Jul 28, 2015 2:30 pm Post subject: |
Trekker182 wrote: |
Technically... the door size and basic outer shape NEVER changed for the entire Beetle Sedan production timeline..
So in essence... a 49 door will "fit" a 77..... and vice-versa.. may look like crap... will fit the slot.... but may not "work"
Ok.. Ill repeat and educate this in a little better detail..
This information applies to "MOST BUT NOT ALL BEETLE SEDAN'S " as many older bodies carried over depending on factory location.
For the 1965 model year ALL the windows were enlarged...
The door "Wing windows" were angled as well during this change.
The door glass line matches the larger quarter window line..
The interior door panels were shortened to accommodate the larger glass.
So that narrows it down to 65 and newer doors.. right...
Nope...
Not.... quite..
For the 1967 model year, the door latch style changed from a "slider" latch to the safer "claw and pin" latch.. also the inside door handle was changed from the ice pick to the flip tab handle and door lock buttons were added.
That latch change means 67 and newer doors WILL NOT interchangeable with older slider latch bodies unless you change the latching to match..
So... .again... that means.. if the body is a 65 and 66 body with the larger glass and your body uses the slider latch...
ONLY the 1965 and 1966 doors will directly bolt on and WORK.. t
Now... for the record.. or off the record...
You CAN bolt 64 and older doors right on.. 1965 and 1966 bodies.. but it looks terrible.. as the side glass lines will be mismatched..
You also CAN convert the 65/65 door latch post to accept the 67 and newer "pin"... but it requires welding in a replacement section as the latch position changed as well.
Class dismissed...
Too bad you dont live here.. I have 2 perfect 65/66 pairs.. complete..
itskyle Samba Member
Joined: October 04, 2013 Posts: 634 Location: Plainfield, IN
Posted: Tue Jul 28, 2015 8:46 pm Post subject: Re: 1966 Beetle Doors |
Trekker182 wrote: |
Thanks
Don |
You might try 1966vwbeetle.com for fellow 66 buggers near your neck of the woods on your side of the pond.
I will take a stab in the dark, I seem to recall hearing that the USA 67 beetle didn't come to Europe or most of the rest of the world until after 68 or so.
So, a 67 euro door might fit. I think the thing to really look for would be the locking and latching mechanisms.
Good luck, Don! _________________ --
69 or 72 Autostick Bug current
66 Bug (We both miss it)
74 SuperBeetle Auto Stick (I miss that car)
73 SquareBack, Straight Stick (Wife misses this one.)
Slow 1200 Samba Member
Posted: Wed Jul 29, 2015 6:00 am Post subject: |
nope, '67 euro doors are the same as '67 US ones |
Posted: Wed Jul 29, 2015 9:40 am Post subject: |
Trekker182 wrote: |
Nope...
Not.... quite..
Class dismissed...
Thanks to everyone for your replies to my question about 1966 doors, in particular Volkswagnut for the detailed and extremely informative lesson in Beetle door history. I thought I knew a lot about Vdubs but despite having several type 1s, a Splitty camper Van, a type 4 412LE estate two Golfs, a Jetta, My beloved Trekker (Thing) and the old 1966 VW but you guys leave me for dead.
Wolkswagnut, If you have any plans to move to the North East of Scotland in the near future, or if your planing a vacation over here can you bring your two 65/66 doors with you?
Thanks again guys
Don |
Posted: Wed Jul 29, 2015 9:59 am Post subject: |
Trekker182 wrote: |
Volkswagnut, If you have any plans to move to the North East of Scotland in the near future, or if your planing a vacation over here can you bring your two 65/66 doors with you?
Don |
You're welcome..
Im afraid to leave my own house most days..
Wish I could help you with one of my clean pair.. .. Its actually hard to sell 2 year only doors around here.. .....
Usually and often edited |
Posted: Wed Jul 29, 2015 12:07 pm Post subject: |
Trekker182 wrote: |
Don |
You're welcome..
If I could find a way to get your two doors over here without breaking the bank I would. |
Posted: Thu Aug 06, 2015 6:33 am Post subject: |
Trekker182 wrote: |
Trekker182 wrote: |
Don |
You're welcome..
Would you consider selling your doors? if so I would probably buy them from you. I would have to find out the shipping cost to the UK but I am keen to buy both your doors, I take it your doors are a pair and not two of the same side.
Cheers
Don |
Posted: Sat Oct 24, 2015 8:32 am Post subject: |
Trekker182 wrote: |
Trekker182 wrote: |
Trekker182 wrote: |
Just an update on my door situation. I managed to find out that there was a 66 Beetle being broken up for spares at a breakers yard down beside Edinburgh, and by the time I found out about it there was nothing left but the body and the doors. My wife and I headed off on a 250 mile round trip, with a selection of tools in the van, knowing that we had to remove the doors ourselves and that they probably hadn't been off the car in nearly 50 years. However with a big hammer, an impact driver and a bit of desperation we got both doors off, paid the 80 UK Pounds and headed back North with two 1966 doors in the back of the van. My wife questioned my idea of a "nice day out"
Don |
You're welcome..
Cheers
Don |
