randallino Samba Member
Joined: February 14, 2011 Posts: 6 Location: North Mississippi
Posted: Mon Jul 27, 2015 2:23 pm Post subject: My '66 barn-find, with some mysterious parts |
I'm trying to determine the order of operations here. This is a 1966, with what appears to be a 1960, 1200 engine in it.
In the barn, where I found her
Engine compartment (pre-cleaning)
Cleaned up and in my driveway!
This thing sat for over 30 years. The wiring was eaten by critters, and the battery is long dead. I happen to have an alternator, stand, and coil from a 12 volt set-up in my old VW treasure box, and a 12v marine battery for a trolling motor. I also have32 PICT and a 34 PICT Solex that I've stored in plastic bags all these years. So...
Since the engine is not the o.g. 1300, I'm not committed to keeping it stock. What I'd like to do is get a battery, rebuild the carb, clean the tank and wire up just the starter and ignition system for a test run. But do I buy a 6v battery to test with, or install the 12v parts and battery and run it that way?
I know I need new points and condenser, too. I don't recall the distributor model, but it's got the biscuit on the side. I can check the model and update. I'm really eager to see if the motor is any count, so I'm looking for the simplest way to test it. I've also considered buying a 009 and matching it with the 32 or 34 PICT, whichever is appropriate. I'm not sure if I'll be keeping this engine or getting a rebuilt 1600+, so I don't want to buy parts I can't swap over. I'm about 10 days in, mostly cleaning and assessment but I appreciate any insight.
[/img] |
rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Posted: Mon Jul 27, 2015 2:44 pm Post subject: |
Welcome.....that first photo is awesome! _________________ '65 Sunroof Bug |
stale air Samba Member
Joined: August 23, 2007 Posts: 5148 Location: Senoia Ga, formally NorCal
Posted: Mon Jul 27, 2015 2:48 pm Post subject: |
Grab the numbers off the motor, and you can look them up to find out exactly what year the motor is. It appears to be an early 40 horse and is for sure not out of a 60 as that would have made it a 36 horse. _________________ WANTED: Henry Veale Santa Rosa plate frames
grandpa pete Samba Member
gt1953 Samba Member
Posted: Mon Jul 27, 2015 4:24 pm Post subject: |
Just remember there is never a dumb question.
Do take your time and done correctly the first time.
This is probably the best air-cooled VW site. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Tue Jul 28, 2015 2:05 pm Post subject: |
Thanks for all the feedback! i'm pretty in love with that photo in the barn, too. I may have to frame that one.
The engine number is 5042648, which looks to be a 40hp 1200 from a '61. I'm curious if the 28 PICT carb and the distributor are stock for that year. I've read a lot that the distributor and the carb need to match, so I don't want to get a 009 unless I can use one of my spares (I have a 32 & a 34 somewhere).
I should note that the engine turns over by hand, and allegedly ran when parked.
After removing all rotten hoses & wires
Close-up of the distributor
Anoter close-up, this one of the innards
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Tue Jul 28, 2015 2:08 pm Post subject: |
That shroud looks to have been modified on the left outlet to make room for an A/C compressor. Poor li'l 40 horse! |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Jul 28, 2015 3:09 pm Post subject: |
KTPhil wrote: |
^^^ Or a dusty conditions oversize oil bath air cleaner.
Before you go hog wild and start throwing away the top end of that motor- I implore you to learn a little about it. It looks more like a bastard 40 horse bus motor to me- with a later ('63 and up) fan shroud. Firstly, an "009" distributor has never benefitted a 40 horse engine. Over carbing has also never benefitted that lump. Research Bastard 40- and you may not want to do much with it. _________________
EverettB wrote: |
FU#5 |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jul 28, 2015 5:11 pm Post subject: |
stale air wrote: |
Grab the numbers off the motor, and you can look them up to find out exactly what year the motor is. It appears to be an early 40 horse and is for sure not out of a 60 as that would have made it a 36 horse. |
May59 thru 1960 bus had 36 HP engine with separate generator stand used on later 40 HP engines... _________________ In Stereo, Where Available! |
Posted: Tue Jul 28, 2015 7:21 pm Post subject: |
Eric&Barb wrote: |
stale air wrote: |
May59 thru 1960 bus had 36 HP engine with separate generator stand used on later 40 HP engines... |
Since the bastard 40 is a pretty rare motor, I didn't think to mention it. But your right, it very well could have been. _________________ WANTED: Henry Veale Santa Rosa plate frames
Posted: Wed Jul 29, 2015 8:42 am Post subject: |
Lots to consider here.... thanks all!
I think I will rebuild the 28 carb, the distributor, and replace the points condenser, cap rotor & ignition wires. Then either get a used 6 volt battery, or swap my 12 v parts onto it and hook up the marine battery I already have.
I'm reluctant to install a complete harness when I still have pans to cut out and replace, so I figure I'll just rig up an ignition system and push button starter to find out if this motor runs.
That shroud does look rough, I have an un-mutilated one I can swap it for when I switch to the alternator.
I'll have to investigate this 'bastard bus' motor. I might be able to some info from the previous owner, but that's doubtful. |
Posted: Wed Jul 29, 2015 9:34 am Post subject: |
Do keep in mind that if the wiring was eaten all up, that more than likely the mice built nice nest/s in the fan shroud. Which will block up the cooling to the heads and cylinders, so would not run it for more than a minute.
If it runs, it needs a full strip down to long block for a good cleaning and retorquing of all the engine case and then heads fasteners in same sequence as if building the engine.
As for the case ID number it looks like it might be a hand stamped (slightly crooked numbers) at a dealer replacement case. _________________ In Stereo, Where Available! |
Posted: Thu Aug 18, 2016 8:34 am Post subject: Re: My '66 barn-find, with some mysterious parts |
Well it's been a little over a year and about all I've done is pull the motor. I've also completed quite a few chores on my honeydew list, re-organized my shop to accommodate a bug for the foreseeable future and add a lot of lights so I can what I'm doing.
The motor mystery is solved, I think. I pulled it about 2 weeks ago and it turns easily by hand. I'm thinking of cleaning it up and putting it back in to see if it works.
Here's a pic of the number
Posted: Thu Aug 18, 2016 8:38 am Post subject: Re: My '66 barn-find, with some mysterious parts |
You can see a small '78' stamped just above the P, and some odd marking after the number. sorry the pic is blurry
There is also a very faint stamp below gen stand that says Factory Rebuilt. |
Posted: Thu Aug 18, 2016 9:01 am Post subject: Re: My '66 barn-find, with some mysterious parts |
More images of the motor.
bluebus86 Banned
Posted: Thu Aug 18, 2016 11:46 am Post subject: |
KTPhil wrote: |
the fan house is not from a 60 bug as it is a fresh air type and it has been modifed like was done for an ac compressor I think the fresh air fan shroud started in 62, I know the 61 had stale air heater
hope she restores well for you _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
splitjunkie Samba Member
Posted: Thu Aug 18, 2016 12:56 pm Post subject: |
bluebus86 wrote: |
KTPhil wrote: |
hope she restores well for you |
The fresh air shroud was introduced for the '64 model year.
The modified air outlet is indeed for a dealer installed air conditioning system.
My '65 was purchased new by my grandfather and he had the dealer install air conditioning. _________________ Chris
Posted: Thu Aug 18, 2016 1:04 pm Post subject: |
splitjunkie wrote: |
The fresh air shroud was introduced for the '64 model year. |
Actually DEC62.
bluebus86 Banned
Posted: Thu Aug 18, 2016 1:27 pm Post subject: |
bluebus86 wrote: |
KTPhil wrote: |
My '65 was purchased new by my grandfather and he had the dealer install air conditioning. |
Golly I could have written your above post.... my granddad bought a brand new 65 bug back in the day and he had the dealer ac option too, I have that car now!!!!! I guess we both had pretty wise grand dads!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
