daanbc Samba Member
Posted: Mon Jul 27, 2015 4:38 pm Post subject: Blinker buttons 98% done! |
From my recent posts "Is a resistor needed, and how to wire" I finally received the resistors and soldered everything together. I like the way it came out! Much better then the stalk I kept hitting with my big feet. The electronic signal cancelation device is great! No sound and it has different settings. Press the button once for a second and the flasher signals for 7 sec. Hold the button 3-sec, and the signal flashes 15 sec. Hold it a little longer, and it will flash 25 sec. Hold both buttons at the same time, and you have hazards! Here are some pics. I have the resisters in the red power line heat shrink wrapped. I used a wood 3/4 inch drill for the holes. I have a horn button coming next week, that has a blue LED also that has a symbol of a horn lighted up in it.
GoMopar440 Samba Member
Joined: February 06, 2015 Posts: 491 Location: Montana
Posted: Mon Jul 27, 2015 8:53 pm Post subject: |
Looking good so far. I don't envy your clean up job after drilling that FG dash though.
That's a shiney looking E-brake button you got there... _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Link to my rail (re)build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=629493
daanbc Samba Member
Posted: Tue Jul 28, 2015 1:23 am Post subject: |
Thanks, Hardest part of this project was getting the nut back on the back of the switch. With the tip of my finger missing and it being real sore, it was a real pain. Would you believe "someone" made that E-Brake button for me? LOL. I'm going to try to get to the local junkyards tomorrow if the weather holds, and look for a shift boot or something to fit over the E-Brake. I don't like the rubber cover thats there. |
TSFR Samba Member
Joined: May 14, 2013 Posts: 365 Location: Columbia, SC
Posted: Tue Jul 28, 2015 5:12 am Post subject: |
you have those blinking with the lights too right? _________________
Thanks,
Jeff
Manxter 2+2 #160 |
daanbc Samba Member
Posted: Tue Jul 28, 2015 6:28 am Post subject: |
TSFR wrote: |
you have those blinking with the lights too right? |
No, I was thinking of that. But am unsure if it can be done. There was only two ways to hook them up. One - with the LED's always on. and Two- they only light when the switch is on. BUT since they are momentary switches, I figured they would stay lite only when pushed in. |
TSFR Samba Member
Posted: Tue Jul 28, 2015 7:11 am Post subject: |
I have the same switch for my hazard lights and it can be done. I want to say that the power goes through the switch to the flasher relay and then the power that goes to the lights jumps off to light the switch as the lights flash. _________________
Thanks,
Jeff
Manxter 2+2 #160 |
daanbc Samba Member
Posted: Tue Jul 28, 2015 7:29 am Post subject: |
TSFR wrote: |
I have the same switch for my hazard lights and it can be done. I want to say that the power goes through the switch to the flasher relay and then the power that goes to the lights jumps off to light the switch as the lights flash. |
I don't have a relay. I have the signal cancelation device. But I'm going to check on it, to see if it can be done. Thanks. Which wiring diagram did you use? The first = lights only on when switch is on, OR second = lights always on.? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Jul 28, 2015 7:45 am Post subject: |
daanbc wrote: |
TSFR wrote: |
The light LED in switch is a independent function, you can leave them off, turn them on with dash lights power or have them blink with turn signals.... It all about how you choose to power (or ground) them....
Having them come on with dash lights seems most practical (so you can find them in the dark) have them blink with turn signal becomes a little more complex because if turned on by dash light switch, you have to have a way to turn them off (interrupts power or ground) when signals are flashing... This means probable adding small relay or transistor into circuit to control them...
But for each feature wiring becomes more complex...
daanbc Samba Member
Posted: Tue Jul 28, 2015 8:05 am Post subject: |
Dale M. wrote: |
daanbc wrote: |
TSFR wrote: |
Dale |
Thank you dale. Yes I have them hooked up when the key is on. I did not wire them into the headlight switch. I really don't want to add a relay. I'm not an electrician, and my abilities are not as good as some. I figured if I really didn't like the lights on during the day, I could always add a on/off switch under dash just to the LED lights, this would still allow the function of the blinkers. |
daanbc Samba Member
Posted: Tue Jul 28, 2015 4:37 pm Post subject: |
Finally got the tags put on. They have been sitting on the bench for weeks. These were the originals from the beetle of the frame.
jspbtown Samba Member
Posted: Wed Jul 29, 2015 7:43 am Post subject: |
You don't need wipers in FL to register a car? |
AMAC1680 Samba Member
Joined: April 09, 2015 Posts: 300 Location: Jacksonville Fl/Mantoloking NJ
Posted: Wed Jul 29, 2015 9:28 am Post subject: |
jspbtown wrote: |
http://www.leg.state.fl.us/Statutes/index.cfm?App_....2952.html
Yes they need wipers. Many buggys just use "blanks", for show only.
The requirement is asinine as they don't require a roof. Therefor if it were for safety they would require wipers on BOTH sides of the windshield, lol.
It could be argued that a squeegee would meet the definition.....
Fact is down here you would need to be caught for something else. They don't look at the car when it's registered and we have no required inspection.
God I love it here.
Be Big,
AMAC |
daanbc Samba Member
Posted: Wed Jul 29, 2015 9:46 am Post subject: |
If I get caught in rain, I'll just use my hand and a squeegee. LOL. Really I have a lot of rain x on it. It just beads up and rolls off. |
Posted: Wed Jul 29, 2015 10:45 am Post subject: |
So they cannot pull you over for having a car like daanbc (ie: no wiper arms at all)? Only if speeding or some other offense? |
Posted: Wed Jul 29, 2015 11:26 am Post subject: |
jspbtown wrote: |
Oh they can and depending on what part of Florida they will. If you run antique plates you beg to get pulled over in many areas as they have become aware of the regs tied to theses plates.
That buggy is more likely to be pulled over for lack of a rear bumper. That's something even a novice cop will notice.
In most parts of "Old Florida" the cops never look twice.
I would put the arms on unless you're will to try the squeegee defense.
Of course if the car is a show piece or trailer queen it doesn't matter. I drive mine every day past the same cops so I prefer to be legal, although my currant ride needs the bumper put back on.
AMAC |
daanbc Samba Member
Posted: Wed Jul 29, 2015 12:07 pm Post subject: |
You can always get the "old fashion" kind, the one used by hand. Like on the old fords. |
Posted: Wed Jul 29, 2015 12:10 pm Post subject: |
That's so interesting. They don't prevent you from getting on the road with a car that's "illegal" but they ticket you once you are there.
Up here in Mass we have annual inspections. |
daanbc Samba Member
Posted: Wed Jul 29, 2015 1:20 pm Post subject: |
There are no inspections here. When there was if your car was over 25 years it was excempt. Also doesn't hurt if you work/ or know law enforcement.
Posted: Wed Jul 29, 2015 3:53 pm Post subject: |
jspbtown wrote: |
When you sign for the registration you are making a legal statement that the ride meets state regulations. So they can get you later. Guess it's the last of "personal responsibility".
I lived in NJ for years and the inspections were just more government interference. Proved almost no point I beat that system more times then I could count.
On another note.
Knowing law enforcement may work in ones own backyard but it's bullshit and I wouldn't publicly admit to that behavior.
AMAC |
daanbc Samba Member
Posted: Wed Jul 29, 2015 5:23 pm Post subject: |
AMAC1680 wrote: |
jspbtown wrote: |
On another note.
AMAC |
