andreasschmieg Samba Member
Joined: March 10, 2004 Posts: 81 Location: Minneapolis, MN, USA
Posted: Mon Jul 27, 2015 7:05 pm Post subject: Ruined Hole for Engine Stud - Best tool to tap and sleeve it |
So I have four disassembled engines on the shelf. A 1600 that came in boxes with my 1967 Beetle, a 1500 Industrial Engine that has all the right parts except for the correct H0... case, a correct H0... case engine that actually had 87 mm pistons and cylinders on it, and a busted 1500 parts engine for $25.
The idea was to use most of the industrial engine plus the correct H case and build an engine that is as close to matching numbers as it gets. The VIN and engine number are only a month apart.
With my luck, one of the engine studs came out with a whole lot of extra metal on it and now the thread in the case is ruined. The thread on the stud was twisted at the end and stripped all the thread out of the case.
Where can I get the best tap and sleeve tool to fix this and use a regular engine stud?
Thanks for any help!
Andy _________________ ~~~ Dont trust cars under 30! ~~~ |
grandpa pete Samba Member
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Jul 28, 2015 6:54 am Post subject: |
http://www.timesert.com/
the only way to go
rent one here
http://vwparts.aircooled.net/SearchResults.asp?Search=timesert+rental _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Tue Jul 28, 2015 10:25 am Post subject: |
Thanks! The Time-Sert product looks great.
The engine block is an H0... 1500 made in November 1966.
Does anyone know of the cuff which size and depth to get?
Does that mean 8mm studs?
Thanks,
Andy
P.S.: I am still amazed how much knowledge I simply forgot by not playing with classic Beetles for about a decade. I can barely remember the years and models of the fifteen Beetles I had in the 1990s. Getting old. _________________ ~~~ Dont trust cars under 30! ~~~ |
Posted: Tue Jul 28, 2015 10:53 am Post subject: |
http://vwparts.aircooled.net/Time-Sert-Tool-Rental-10-x-1-5mm-1015-p/time-sert-rental-1015.htm
8 mm as in head studs? later cases used 10 mm studs
Yeah it's amazing how stuff goes by the way side when you aren't involved with it each day _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Wed Jul 29, 2015 7:55 pm Post subject: |
Thanks! I just ordered my Time-Sert tool set and 16 inserts. _________________ ~~~ Dont trust cars under 30! ~~~ |
