Mrjaydeem Samba Member
Joined: July 22, 2015 Posts: 15 Location: Chesapeake, Va
Posted: Tue Jul 28, 2015 5:50 pm Post subject: wiring harness swap. |
Hi fellas,
New to this bug world. I bought me an 1975 Standard bug. it's a carb, not an fi. The wiring harness is cut in few places. Also, its a rat mess and i do not know where everything goes. Most of the wiring is unplugged. I couldnt pass up the price I paid for this project. I tried to look for a brand new wiring harness to buy and install it and be done with it but, no one makes anything after 74. i was wondering will I run into any trouble if I bought harness that is for pre 70's?
I dont really care for the dome lights or anything fancy. Just the working headlights/tails/turn signals/ and of course running car. |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Tue Jul 28, 2015 7:44 pm Post subject: |
Can you match the colour codes of the cut wires? That might be easier ... repair them one by one
There were changes in the wiring and fuse box shape around 1971/2: the later cars had the blinker/headlight relays (box thingies) mounted on the fusebox frame under the bonnet where the earlier cars had them installed on a steel post behind the speedo
The wiring in a Bug is a little "casual" from the factory! |
Posted: Tue Jul 28, 2015 8:04 pm Post subject: |
The head lights are snipped, harness that goes out to the engine bay are snipped up as well. Under the bonnet is another story...
Would been better if i knew where everything went but i bought it this way. |
sb001 Samba Member
Posted: Tue Jul 28, 2015 9:29 pm Post subject: |
None of the usual vendors I've seen carries the 75-up harness either.
This is probably your best bet, they'll actually make one for you from scratch that's an exact duplicate of the original:
http://www.vwlooms.com/
It won't be cheap though. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Tue Jul 28, 2015 10:01 pm Post subject: |
I appreciate the link. Ill shoot them an email for a quote. |
Posted: Wed Jul 29, 2015 6:27 pm Post subject: |
Anybody else knows? |
Posted: Sat Sep 12, 2015 8:30 pm Post subject: |
Never heard back from vwlooms after 2 months. |
Bugzilla Samba Member
Joined: February 08, 2004 Posts: 240 Location: Rapid City, SD
Posted: Sat Sep 12, 2015 8:56 pm Post subject: |
I bought this one, but I am actually building a baja so I can probably use anything...
I would be willing to trade, I will probably just harvest the wires off of it anyway.
It is for FI though... maybe check the technical area for a wiring diagram to see what the difference is.
T |
Posted: Sat Sep 12, 2015 9:24 pm Post subject: |
My car used to be a fi but previous owner convert it to carb. Its going to be a volksrod. Im hoping i can buy pre 70s wiring hardness kit but what about the steering colum wiring? |
Posted: Sun Sep 13, 2015 7:16 am Post subject: |
PM sent.
T |
