stephenvw1776 Samba Member
Joined: December 24, 2014 Posts: 27 Location: Los Angeles
Posted: Tue Jul 28, 2015 11:29 pm Post subject: Fan shroud advice |
What fan shroud would the samba community recommend for a setup using a remote oil cooler only?
The engine will be open either a sand rail or Baja bug. |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Wed Jul 29, 2015 12:18 am Post subject: |
....signature line... _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Wed Jul 29, 2015 6:26 am Post subject: Re: Fan shroud advice |
stephenvw1776 wrote: |
I personally always recommend that people use the doghouse shroud and cooler, even with external coolers but that is just my opinion. I know people successfully use non doghouse shrouds as well. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Wed Jul 29, 2015 4:17 pm Post subject: |
There are type IV conversions where the builder uses a non dog-house factory shroud but fabricates a box for the cooler and gets air flow to it from a fan shroud heat exchanger outlet _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Wed Jul 29, 2015 5:46 pm Post subject: |
WELCOME.
Growing up in this game at local VW dealers where many of us had sand rails and such, it was common knowledge that it took years to get a few thousand miles on a sand rail engine. That said, you can possibly get away with parts that a street engine would not be desirable. I am thinking of the 70 and earlier shroud with the steel cooler and add a full flow to your case. Then if needed you could plumb an additional cooler to the full flow circuit. Many people like the Scat 36hp style shroud using the dog house cooler. Being a buggy guy many of these items can be sourced cheap around SoCal.
Hope this helps, Bill. |
mark tucker Samba Member
Posted: Thu Jul 30, 2015 7:15 am Post subject: |
36 doggy style |
Posted: Thu Jul 30, 2015 7:10 pm Post subject: |
Thanks for all the replies!
What about the "ram flow" air shrouds? I saw them in a CB Performance catalog years ago and they are used with an external oil cooler only. Any experience with those?
I'll put the signature soon |
Posted: Thu Jul 30, 2015 7:51 pm Post subject: |
Now I have a siggy. _________________ 1970 VW Bug (first car) sold...
1965 Baja cost me $100 sold...
Current project:
Sand Rail
-1835, 8.5:1 CR, w100 cam, dual Dellorto FRD 34 carbs |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Thu Jul 30, 2015 9:42 pm Post subject: |
Take a doghouse shroud and remove the doghouse, patch the hole. Now you have a no-cooler shroud. Run a 1500 size cooling fan for a little more power to the wheels, don't need as much volume if there is no cooler or heater.
Don't want to butcher a stock shroud get a scat one. They are almost as good. They could make the shroud with no doghouse, but they don't.
The slant top looking shroud they forget the vanes inside, so it doesn't cool the left side of the engine very well, they are for show not go. |
bluebus86 Banned
Posted: Fri Jul 31, 2015 6:33 pm Post subject: Re: Fan shroud advice |
stock fan houses are near always better than aftermarket ones. better welds, stampings and fit, and most lack the factory internal vanes so critically placed to get the cold air to the hottest spots.
Avoid the poor fit and performance of aftermarket parts.
as far as the best factory shroud, that would be the late fuel injected smog controlled Bug shrouds, as that style actually sent a greater portion of air to the heads than the oil cooler (the last Bug had to meet smog standards that caused the heads to run much hotter) VW sacrificed oil cooling air for head cooling air on these last (maybe about 76 and later??) shrouds AND these shrouds came equipped with the venture ring on the inlet!
These are the best Dog House shrouds if you are using an external cooler and keep the stock cooler in the shroud. The external cooler makes up for any loss in oil cooling from the stock cooler with reduced air flow.
This way you do the best for the heads.
You could I suppose block the stock cooler so that all the air is used on the heads (and cylinders too), but there is a possibility that doing so might upset the air flow balance between the heads so that one side might run hotter than the other. I also figured I wanted to retain the stock oil cooler so I would not be 100% dependent on an electric fan for my oil cooling in my kit car.
So look for the later smog control bug fan house, it will have the venturi ring, but note that venture rings are being sold to install on fan shrouds, so it could be an add on ring, not stock. (the rings are a great idea to add to any fan house that lacks one)
good luck, stay cool!!!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
