nvmipis1 Samba Member
Joined: August 25, 2012 Posts: 246 Location: riverside , ca.
Posted: Tue Jul 28, 2015 11:41 pm Post subject: I want this stance, help, suggestions etc thanks, lowering |
I want to know hoe to get this stance, I currently just have flipoed spindles with alk stock trans with reduction
Posted: Tue Jul 28, 2015 11:45 pm Post subject: |
Im looking to get this stance , best advuse and on a budget, I know I can easily drop close to $3500- $4500 for this bit best advice will be great thanks vw family
Here is a picture of my current situation
Stephbong Samba Member
Joined: January 11, 2010 Posts: 167 Location: Brussels
Posted: Wed Jul 29, 2015 1:38 am Post subject: |
Looks like you already have the good tyres size
Of course you'll need an adjustable/narrowed beam ( 4 inchs?) and go IRS back |
donald.lemay Samba Member
Joined: March 01, 2009 Posts: 484 Location: Rhode Island
Posted: Wed Jul 29, 2015 1:50 am Post subject: |
you might have to raise steering box and tub to achieve that look. Theres a seventy six page sticky, lots of guys giving up there combo's. _________________ 66 13 window deluxe
2085cc
9to1compression
ported polished heads 40x36 valves
010 distributor
VS 42mm exhaust
40 IDF carbs |
Posted: Wed Jul 29, 2015 4:37 am Post subject: |
with those low profiles tyres not sure he will have to tub but yes I agree on the steering rise |
Pinetops Samba Member
Posted: Wed Jul 29, 2015 6:45 am Post subject: |
I would consider leaving the height like it is and putting that money into a paint job. I'm not trying to be a jerk, sorry if that comment came off that way. Just my honest first thought. _________________ "A rolling bus gathers no rust." |
Posted: Wed Jul 29, 2015 7:01 am Post subject: |
Irs? Does thatmean new type 1 tranny,? I was told that by changing out my axels to type 3 will also help with tranny and allow my sc to run faster |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Wed Jul 29, 2015 8:04 am Post subject: |
I know that bus, we hanged out at Prado with you and your girls. You should make your own lowered front beam and side plates, and narrow it yourself too. My buddy has a single cab that he did that with and it is slammed.
_________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Posted: Wed Jul 29, 2015 1:18 pm Post subject: |
Do you have pictures or information on how or what he did, and I remember how was the drive back to Arizona? ? Pretty hot huh ? But yeah I want a better stance on my sc |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
GTV Samba Member
Posted: Wed Jul 29, 2015 4:45 pm Post subject: |
Red Fau Veh wrote: |
I know that bus, we hanged out at Prado with you and your girls. You should make your own lowered front beam and side plates, and narrow it yourself too. My buddy has a single cab that he did that with and it is slammed. |
If you're talking about Chris that was a CB 2" beam that he cut an extra 2" out of. It's lowered for sure, but it's not slammed at all _________________ EMPI Power Rules! |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Wed Jul 29, 2015 6:24 pm Post subject: |
You can get there with some work...
Straight axle kit in the rear
Adjusters on your beam
Stock wheels will help with tuck in the front, but you can also narrow a little more for BRM offset
Check out the links above for answers! _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Posted: Wed Jul 29, 2015 9:33 pm Post subject: |
I am going to do 4" narrow beam with adjusters, my spindle are already flipped and going to stick with the current wheels on sc speed master wheels, straight axel kit? I do not have to change out my tranny? I was under the impression that I would need to switch to a type 1 tranny and if im doing that might as well go with freeway flyer caused this stick trans SUCKS! cant go past 55mph |
lo-lo55 Samba Member
Joined: April 08, 2004 Posts: 61 Location: christchurch New Zealand
Posted: Thu Jul 30, 2015 1:52 am Post subject: |
Freeway flyer rebuilt trans if you can spend the $, put it all together right and be done with it. Might need a small notch in the frame rails for your tie rods too, mine was that low but raised it a click didn't want to notch it or raise the box. Four inch beam with flipped spindles also, will be a cool truck when your done. |
lowindO Samba Member
Posted: Thu Jul 30, 2015 10:18 am Post subject: |
With that stance and that driveway, your definitely going to need a steering box raise. Even then you will still scrape the bottoms of your front bumper over riders.
Also, you will have to change your exhaust. I recommend the vintage speed sport exhaust for lowered buses, but a stock exhaust will work if you cut the tip off some. Maybe A1 sidewinder or csp Python as well but I'm not as familiar with those.
Your atleast gonna want 4" but for the stock rim, king tuck look you'll be happier with a 6"+ with the speedmasters. Have you seen the panscrapers or maybe it's radikal bugs, blue pressed bumper SC on speed masters?
If your changing trans out, think hard about whether to go IRS or swing axle, as your gonna be changing out everything as you go. This can also be a good time to think about brake upgrades.
In the back I'd say either go IRS or get the offset dogleg adjustable plates.
If your thinking about tubs, how tall are you? How big are you? I've sat in tubbed buses, I am not a fan unless you modify the seat to remain in the stock location.
It's crazy how 3 more inches can be so much work and cost $! _________________ Why don't you have a narrowed beam yet?
My Squareback's Video |
Posted: Thu Jul 30, 2015 3:56 pm Post subject: |
inspiration, more narrowed beams with stock wheels.
Posted: Thu Jul 30, 2015 5:43 pm Post subject: |
lowindO wrote: |
It's crazy how 3 more inches can be so much work and cost $! |
I haven't done the narrowed beam yet Wil do soon. But what is the difference between irs and swing axels on a bus? Pros n cons? And i want to stick with the speed masters only cause i haven't seen many single cab with tjese wheels and i want to be a littlw different so i shoild go with 6" up front? |
Posted: Thu Jul 30, 2015 5:44 pm Post subject: |
lowindO wrote: |
Those school are pretty clean that's the stance i want but i want to stick with speed master wheels |
Posted: Thu Jul 30, 2015 5:47 pm Post subject: |
lo-lo55 wrote: |
That's what i was thinking but someone told me tjay i dont have to to all tjay work thay my normal stock trans woild be just fine...just remove the reduction and install type 3 axels and yeah i am definitely going to pit disks brakes in the rear and i wamt to this this right since im going to be taken everything off might as weel put it nack right and with proper upgrades after all i am on a budget |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Jul 30, 2015 6:29 pm Post subject: |
nvmipis1 wrote: |
lo-lo55 wrote: |
yeah that is fine as long as it is okay with you to have 4 reverse gears and 1 forward.... _________________ regards
Uli
