grandpa pete Samba Member
Posted: Wed Jul 29, 2015 9:40 am Post subject: Vinyl spray paints ? |
I have a set of door panels that are black . I want gray ones .
Does anyone have any experience using vynal spray on doorpanels ?
Brand used ???
Photos ???
I was watching a TV show where they spray painted a plastic Frisbee . they used a special primer
Anyone know about vynal paint primers ?
Thanks ..... _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
Jon's62 Samba Member
Posted: Wed Jul 29, 2015 9:51 am Post subject: |
There are a number of options out there; Duplicolor makes a pretty good product, SEM is even better. The key, like everything else is prep. You need to thoroughly clean the surface with a special vinyl cleaner. Some pros very light scuff the surface to get better adhesion. I would advise caution with that last step as you want to go from a dark colour to a light one. It may take a few coats to achieve the look you want. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
carcrazed Samba Member
Posted: Wed Jul 29, 2015 10:50 am Post subject: |
X2 on SEM products. I have sprayed many vinyl items with SEM and have had no issues. It sprays and covers excellent and have had much better luck than the pooplicolor products. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
stale air Samba Member
Joined: August 23, 2007 Posts: 5155 Location: Senoia Ga, formally NorCal
Posted: Wed Jul 29, 2015 11:19 am Post subject: |
carcrazed wrote: |
X2 on SEM products. I have sprayed many vinyl items with SEM and have had no issues. It sprays and covers excellent and have had much better luck than the pooplicolor products. |
X3 for sems. Back in 2010 if had some green and grey matched up, and I resprayed my panels. Turned out great, and has held up great.
Bad lighting, but you get the idea.
_________________ WANTED: Henry Veale Santa Rosa plate frames
Posted: Wed Jul 29, 2015 11:37 am Post subject: |
stale air wrote: |
carcrazed wrote: |
Thanks for the photo ; I hadn't thought of two toning mine but now I probably will . _________________ 63 two fold rag
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Posted: Wed Jul 29, 2015 11:43 am Post subject: |
grandpa pete wrote: |
Thanks for the photo ; I hadn't thought of two toning mine but now I probably will . |
No problem, mine were for my 58, so they were factory 2 toned. 58/59 only. _________________ WANTED: Henry Veale Santa Rosa plate frames
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jul 29, 2015 12:49 pm Post subject: |
If you have spell check working, a red line will appear under the misspelled word. Hover mouse cursor over the red lined word and right click. A pop up window will give you possible alternatives to what you mentally fat thumbed thru....
_________________ In Stereo, Where Available! |
Posted: Wed Jul 29, 2015 12:51 pm Post subject: |
Eric&Barb wrote: |
SO that's what the squiggly red line is for
" It's an old guy thing "
Now can you tell me how to get the free windows 10 upgrade ?
NOTE : my 8 year old laptop isn't even set up for e mail . _________________ 63 two fold rag
Posted: Wed Jul 29, 2015 1:01 pm Post subject: |
Personally not going to windows 10... Looking into Linux, supposed to be easier on older computers so they end up faster running.
Would be good if you changed the title for other to be able to find this info! _________________ In Stereo, Where Available! |
Posted: Wed Jul 29, 2015 1:05 pm Post subject: |
Eric&Barb wrote: |
Would be good if you changed the title for other to be able to find this info! |
Why? no one uses that function, it is the norm to ask in forum _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Jul 29, 2015 1:09 pm Post subject: |
I typed "vynal" three times in the dark in front of a mirror, and poof!, my desktop got windows NT.
Count me in as vote number 4 for SEM. _________________
EverettB wrote: |
FU#5 |
Posted: Wed Jul 29, 2015 4:28 pm Post subject: |
Isn't Windows '95 state of the art anymore?? _________________ 1965 Herbie Replica. 1776cc dual Kads.
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Wed Jul 29, 2015 4:33 pm Post subject: |
I'm another supporter of SEM. About 12 yrs ago I had some dark blue and some black door panels which I painted off-white with the SEM spray paint. Good prep of the panels is 80% of getting good results; the remaining 20% is spraying technique.
To prep the panels, I scrubbed them with SimpleGreen and either a magic eraser or a kitchen dish scrub brush. Get the edges also. Rinse off with a light water spray like out of a plant watering can. Wipe the surface off dry, then set the panels out in the sun for 1/2 hr or so. Wipe the surface off with a degreaser such as isopropyl alcohol, or even Windex spray. Wipe off fully. Blow off with compressed air, then set in the sun again. Set the spray can out as well so it warms up a bit. I set the panels flat on the top of 2 garbage cans and some 5-gal buckets, but a slight angle is OK.
SHAKE the spray can! Go over the surface with a light sweep going all the way across. Don't break up your sweep part way! Give the edges a similar shot. Go to the next panel and repeat. Go back to the first one and apply a similar light coat which will cover alot more. The first light coat will be tacky and the 2nd coat will stick better. Go to 2nd panel. Give the first panel a final (3rd) coat, then bring it inside to dry out of the outdoor dust and insects. Let dry for 2 days. IIRC 1 can was enough for the 4 interior Beetle panels.
@StaleAir- your resprayed panels look great! |
iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2041 Location: M*ssholia
Posted: Wed Jul 29, 2015 6:20 pm Post subject: |
stale air wrote: |
carcrazed wrote: |
do you have part #s or color #s for those colors? Thinking about doing the same for my 58'
Thanks |
GB2S Samba Member
Posted: Wed Jul 29, 2015 6:35 pm Post subject: |
Two questions:
Where do you buy SEM products?
Can you use it to dye a vinyl sunroof?
Geoff _________________ 1963 Ragtop |
Karly Samba Member
Joined: August 01, 2002 Posts: 641 Location: Australia
Posted: Wed Jul 29, 2015 6:59 pm Post subject: |
I had a go with some vinyl dye painting some wheel trims and the colour looks great but my prep was poor! I think I needed to scuff them up a bit as in many spots it is peeling off.
Does anyone have suggestions on what I use to remove it and start over? _________________ 1960 Beetle ''Heidi" daily driver
1964 Karmann Ghia project |
TheDon Samba Member
Joined: July 14, 2005 Posts: 498 Location: Windermere
Posted: Wed Jul 29, 2015 8:05 pm Post subject: |
GB2S wrote: |
Two questions:
Geoff |
The internet of course!
Or use their web page to locate a local purveyor of their line of fine products. _________________
lawn ninja wrote: |
Every time I crush a fat chick I feel like a I save baby kittens and baby kittens are important to everyone. |
