dutchman Samba Member
Joined: August 19, 2004 Posts: 38 Location: Louisville,ky
Posted: Wed Jul 29, 2015 2:29 pm Post subject: 97 golf 5th gear |
Just started experiencing this problem with my golf 2.0 5 speed manual. It is very hard to get car into 5th gear. It makes a sort of grinding noise and is very difficult. No problem with any other gear at this point. Any suggestions as to what this may be or what I can do? _________________ "80% of life is just showing up" Woody Allen
65 beetle |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Wed Jul 29, 2015 8:49 pm Post subject: |
Check gear lube level. May be too late. |
veedubman72 Samba Member
Joined: March 08, 2014 Posts: 230 Location: United States
Posted: Wed Jul 29, 2015 9:14 pm Post subject: |
Bad 5th gear synchro? probably needs replacing |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Fri Jul 31, 2015 2:58 pm Post subject: |
If you jiggle the shifter with the engine off, do you hear a metallic jingle or clanking? If so you need a shifter bushing kit, this can make certain gears hard to find/get into. You may have a bad fifth gear, they are usually the first to fail if the gear lube gets low, check the level. Fifth can be replaced without removing the trans, but depending on how bad it's chewed up, all those pieces find their way into the rest of the trans. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
