esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Wed Jul 29, 2015 9:26 pm Post subject: Loose, but very stuck crankshaft pulley |
I took the car for a several hundred mile shakedown cruise on the 4th of July, and had a blast. Having recently fitted a front whiteline sway bar, and rear 944 porsche bar, and adjustable GAZ rear shocks it was the first trip where I really got to drive it hard. I stopped a few times along the way to adjust the shock settings and check the car over. All in all, it was great, until the ride home. I started to get an occasional buzz/ rattle that wasn't at any specific speed or engine rpm. Must've stopped 20 times, and eventually pulled the rear lid off so I didn't have to keep opening and closing it. And finally I saw it. The pulley is loose.
The berg bolt with the two big belville washers was in w loctite, and it wasn't bottomed out in the bore. When I assembled it, the pulley was a snug fit, or I think it was. It seems that it must've had just enough play to slam back and forth against the key, and distort something. I'm really praying that it's not beaten up the keyway in the crank, but right now I can't even get the pulley off to evaluate what the damage is.
First generation puller
put in a good effort but failed
Take 2
But also failed, started to twist the 1/2" bolt. You can see it's only pulled about 3/16"
So, where to go from here?
I can make a hydraulic puller, but I'm worried that it's stuck well enough that I could cause further damage to the crankshaft that way. Something like this
Or, I thought that maybe I could carefully drill the pulley, just on each side of, and above the keyway. This might relieve the "lock" that's happened, and then a puller would work. Pulling the engine and splitting the case is the last option for obvious reasons.
This really kills me, it's the only Empi part on the car. Berg was backordered on their pulley, and I thought that it's just a dumb pulley, surely it would be pretty hard to screw up, right? Has anyone run into this, what did you do? What not to do? Help?
Thanks. SD |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed Jul 29, 2015 10:06 pm Post subject: |
Seth,
Hard luck man. I wonder if the key broke in two that way you have motion both ways till it binds? Either way its gotta come off. Im hoping you can get it out without tearing up the key way..... keep us posted on what you err... decide to use to take it off.
Can you slip your phone in the betweens and video the keyway as you jog the pulley? _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Do you have stock style pulley puller where claws clamp around pulley? If so, clamp it on in opposite direction you have now, spray penetrting oil front and back of pulley opening. As you tighten puller, smack pulley all around with a plastic dead blow hammer. Also, can use two thin prybars behind pulley and wiggle out ..carefully!......Hopefully the dead blow method works. |
esde Samba Member
Posted: Wed Jul 29, 2015 10:48 pm Post subject: |
rs58rag wrote: |
You know, I'm not a fan of jaw style pullers for stuff that's stuck as hard as this is. It moved ok until it stopped and it hasn't budged at all since it stopped. I've been meaning to make the apron removable for next time the motor comes out, so that's step one. I'll at least have a straight shot at the keyway with a sharp bit.
Maybe a hardened fine thread bolt for my puller?
This is well beyond the realm of wiggling and pry bars. |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Wed Jul 29, 2015 11:07 pm Post subject: |
Have the pulley threads somehow picked up material from the case ? _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
esde Samba Member
Posted: Wed Jul 29, 2015 11:14 pm Post subject: |
gears wrote: |
Have the pulley threads somehow picked up material from the case ? |
Not that I can tell. The whole stuck mess rotates freely in the case. |
platatomi Samba Member
Joined: August 09, 2012 Posts: 465 Location: Los Angeles, California
Posted: Wed Jul 29, 2015 11:56 pm Post subject: |
Drop by Harbor Freight and get a three-size two-jaw puller kit. You can mix and match parts from the three sizes to get the thing to fit the pulley without dropping the engine, and it should pull it right off. Depending on the exhaust setup you have, you may need to pull the header or muffler to get clearance to put a wrench on the puller though. _________________ '69 Beetle daily driver, fixing things as I go...
Update -
No longer daily driver but still fixing things... |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Thu Jul 30, 2015 12:26 am Post subject: |
Sorry about that.
I think you will have to replace the crank.
The ghost of berg that lives in the pulley hates cast cranks, and they got in a fight. It's not the first time.
Look at the bright side you didn't lose the flywheel.
Have DPR make a stroker with porsche width rods! From STEEL
OR
Weld the pulley onto the crank and keep going until the new one is ready. Weld, install bolt, weld bolt. Not joking, I would do it!!!!! |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Thu Jul 30, 2015 4:25 am Post subject: |
I would pound it back again, twist it sideways and try to find another path for it.
Failing that, go with Modoks advice. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
esde Samba Member
Posted: Thu Jul 30, 2015 6:08 am Post subject: |
modok wrote: |
Sorry about that.
OR
I recall that the crank had a really nice ring to it, so I am reasonably sure that it isn't cast. Welding the pulley on really would be a solution, but is a death sentence for that crank as far as future rebuilds go. But it might be done anyway.. bah. Some reading here last night turned up mention of poor quality keys that had broken. We'll see |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Jul 30, 2015 6:26 am Post subject: |
I'm sort in though process of jammed key.... I would drill pulley with 1/4 or larger drill just so edge of hole intersects with key way and try again... No matter what you do, the pulley will be toast so nothing to loose...
mark tucker Samba Member
Posted: Thu Jul 30, 2015 6:57 am Post subject: |
pull the engine take it appart and cut that peice of junk off the crank. I seem to remember somebody saying they wont run those and nobody should.they will do what it did or break crank.........or was that internet hype? if you try to pull it you will effup the crank. |
gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
Posted: Thu Jul 30, 2015 11:54 am Post subject: |
die grinder with a cut off disc!!! _________________ Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness.. |
Posted: Thu Jul 30, 2015 12:16 pm Post subject: |
Then its time to butcher that pulley.... |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Thu Jul 30, 2015 1:52 pm Post subject: |
Hacksaw, die grinder and careful chisel work. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
jpaull Samba Member
Joined: February 22, 2005 Posts: 3460 Location: Paradise, Ca
Posted: Thu Jul 30, 2015 3:07 pm Post subject: |
I would use a plumbing torch with mapp gas (usually next to the propane at your hardware store). with your puller connected and ready to pull, Heat up the pulley close to the center so that you expand it enough and then crank down your puller. Add enough heat and anything will come loose.
Jeff _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Chip Samba Member
Posted: Thu Jul 30, 2015 3:38 pm Post subject: |
I have seen Berg pulleys weld themselves to cranks after flywheels have come loose. Might be time to pull that engine and verify that is not the root cause of your problem. Your crank might already be junk on the other side. Sorry for the disappointing post, but I have seen this or similar twice. Aluminum pulleys crack, steel ones weld themselves to the crank. |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Thu Jul 30, 2015 3:46 pm Post subject: |
Make a wiggle bar that you can bolt to the pulley to try to change it's orientation with the crank. 2 feet long,and eqaually extending past each side of the pulley. Use inertia and smack one of the ends with a dead blow. Next try a little heat. Just get it a little past warm.
Make sure you don't damage the cranks threads with the bolt of the puller inserting it'self into it. If you can't make a decent puller out of a36 steel, buy a cheap puller and modify it. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Brian71 Samba Member
Joined: January 22, 2005 Posts: 183 Location: Prineville, OR
Posted: Thu Jul 30, 2015 4:05 pm Post subject: |
Heat up the outer rim of the pulley with an oxyacetylene rose bud(or map gas torch as an alternative.). The bore of the pulley will grow towards the heat. Apply this in conjunction with the use of your puller. Just be sure you don't allow enough time for the crank to heat up and grow along with the pulley. This should loosen the pulley bore anywhere from .003" to .005" if done properly.. which may or may not help depending how badly that pulley is galled on the crank. If that doesn't work, its time to cut that sucker off. |
