vwsnoopy Samba Member
Joined: February 07, 2008 Posts: 20 Location: South Carolina
Posted: Thu Jul 30, 2015 9:12 am Post subject: 6 volt to 12 volt but still look stockish on a 65 |
I want to switch my 6 volt 1965 bus to 12 volt. I would like to upgrade to an alternator if I can get one that still looks reasonably close to a 6 volt generator.
I've read that there is a Porsche 12v Generator that bolts straight in. Is there a similar alternator? I would prefer to not change the stand. I'll probably stick with the generator if I had to switch.
The other roadblock is the wiper motor. WW sells the replacement motor but it will not fit a 65. I called them and they suggested a Porsche 911 rear wiper motor from a late 60's to early 70 but they did not have an exact year.
Once I get these two hurdles taken care of, I'm ready to go.
Any comments/help would be appreciated. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13282 Location: Tejas!
Posted: Thu Jul 30, 2015 9:31 am Post subject: |
the Porsche 12v 912 90mm generator can be pricy. I have bought and sold them over the years, sometimes you can get a good deal
I don't know of any alternators that look like a generator - they are fundamentally very different, so they look different.
Any reason you want to go 12v? _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Thu Jul 30, 2015 9:36 am Post subject: Re: 6 volt to 12 volt but still look stockish on a 65 |
vwsnoopy wrote: |
I want to switch my 6 volt 1965 bus to 12 volt. ...I've read that there is a Porsche 12v Generator that bolts straight in. |
If your bus is original then your 6 volt generator is 105mm diameter which is the same as all the later 12 volt Bosch generators for up to '71. The 12 volt Porsche generator fits the earlier VW pedestal with the small diameter 6 volt generator.
If you do have a 105mm generator then you'll need the 12 volt pulley also to keep the belt lined up. |
Posted: Thu Jul 30, 2015 2:52 pm Post subject: |
The bus is all original, thus the reason to keep it stock looking.
I'm switching to increase rear visibility (brighter tail lights) at night, and brighter headlights.
Bus is also frying coils. I suspect the generator and if I'm changing it. I am converting
having the ability to get a jump is a big plus as well
I've wrestled with this for about 16 years with this bus .
Better windshield washers are another bonus, 6 volt wipers are almost worthless
So back on topic
The Porsche generator will work with my stand and I need 12 v pulley?
Are they all the same? |
BarryL Samba Member
Posted: Thu Jul 30, 2015 6:56 pm Post subject: |
vwsnoopy wrote: |
So back on topic
The generator that Eric G posted about is the one that fits the smaller 90 mm diameter generator pedestal. Measure your generator body diameter in millimeters. Is the regulator on top of it? I think I told you wrong. Starting in '66 they put the larger 105mm diameter generator on in 6 volt.
I don't know which Porsche pulley you need.
If your generator is 105mm then the world is your oyster for 12 volt generators.
I'm running 6 volt stuff and it all works great. I got the H4 bulbs too. |
Posted: Thu Jul 30, 2015 7:17 pm Post subject: |
I'll
Measure tomorrow. Bus is pretty much bone stock except for the front emblem |
Dana Champion Samba Member
Joined: July 06, 2012 Posts: 633 Location: Ventura County, CA
Posted: Fri Jul 31, 2015 8:29 am Post subject: |
I had a '65 Westfalia that I got back in '75. It was mostly bone stock except it had a later ss vw emblem on the front ('68-'72). Ok, I had air scoops, surf racks, rear bumper hadn't been put back on since swapping out the trans.
I converted it to 12v a few years after I got it. Memory is a litte fuzzy.
Stock 1500 engine, had to change the generator, stand, and pulley . Did not consider a Porsche gen. back then. I think I used a 12v solenoid on the 6v starter, otherwise you need a 12v flywheel, and grind the trans housing. Or did I use a six volt solenoid on a 12v starter. Seems like I had to grind the trans case. Sorry for the fuzzy memory. 12v electric choke. Changed the flasher relay. I never changed the wiper motor. It never rains in California. The wipers worked better, as long as you used them for short periods. It was the 70's man!
Changed the bulbs. Overall it was pretty simple.
If your tail light housings are not shiny inside, I have a simple " fix " to make them brighter. Use metal flue tape inside. I have some pics. from when I did my '70.
Maybe you can find a 12v wiper motor from a '67.
My last splittie was a '63 15 window. I left it 6v... But I sold it! |
captcory Samba Member
BarryL Samba Member
Posted: Sat Aug 01, 2015 9:30 am Post subject: |
Rad. That is dyno! |
Posted: Sat Aug 01, 2015 10:06 am Post subject: |
Ok. Silly question. What part exactly do I need to measure? The half bowl that the generator sits in along the curve?
This is the one presently Installed
Ojai63dbl Samba Member
Posted: Sat Aug 01, 2015 10:35 am Post subject: |
the 12V alternator from Prill could be cool to use-- anyone try it yet or know cost?
alternative is http://www.thesamba.com/vw/classifieds/detail.php?id=1298636
12V in 6V genie - pricey but looks like quality work and no mods to engine or dealing with a worn out Porsche genie |
BarryL Samba Member
Posted: Sat Aug 01, 2015 6:41 pm Post subject: |
Measure the diameter of that pictured generator can. Just hold the measure across left to right of where you photoed and sight down each side. It looks to be the 90mm small size like Porsche and that new fangled one. |
roadkingdoc Samba Member
Posted: Sun Aug 02, 2015 4:32 am Post subject: |
i had my 6 volt generator converted to 12 volt by a shop near me. |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Sun Aug 02, 2015 7:03 am Post subject: |
vwsnoopy,
Here's the solution to the 6v wipers.
http://vw-resource.com/wiper1.html
And if you leave the 109 tooth 6v flywheel on the engine, the 6v starter will last for years on 12v so long as you don't crank it for long periods. But you need to change the starter solenoid to a 12v unit (they are interchangeable) so it throws the starter cog out at a normal speed and does not wear out the flywheel teeth.
If you want to keep it 6v but need better lights, you can now get halogen 6v tail light and headlight bulbs. Same with LED versions too.
If you can't find them anywhere around you, try www.classicandvintagebulbs.com here in Australia. Just remind them you are in the USA so the low beam offset goes to the correct side of the road. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Sun Aug 02, 2015 8:56 pm Post subject: |
roadkingdoc wrote: |
Same here. Took it to an alternator shop that knows Bosch. They had to totally replace the center armature, cost for just the parts was about $100. Cost me $180.
Got a backup industrial engine 90mm 12V generator for much less later. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon Aug 03, 2015 7:43 am Post subject: |
600 for a generator is crazy. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Tue Aug 04, 2015 4:14 pm Post subject: |
j.pickens wrote: |
Ouch. It's a shame you didn't find my $10 fix ( www.vw-resource.com/wiper1.html ) before you spent all that cash. _________________ Rob
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Aug 04, 2015 8:49 pm Post subject: |
M 620 was a popular option in 1965. It was a factory 12 volt system. I'm sure there are some threads on here that detail the changes and apearance. _________________ Roads Scholar &
Posted: Wed Aug 05, 2015 7:30 am Post subject: |
Aussiebug wrote: |
j.pickens wrote: |
Ouch. It's a shame you didn't find my $10 fix ( www.vw-resource.com/wiper1.html ) before you spent all that cash. |
Say what? _________________ Your Vanagon sucks, Stop waving at me.
